Throttle Body Spacer
on
HI i was looking into getting a throttle body spacer for my 350z and i was wondering if it actually worked, iv heard the throttle body spacer sends the air from the air intake into a swirling tornado? if any of you guys have tried one yet please give me some feedback on how it worked and if it really worked? THANK YOU
Master
here ya go
http://www.ecrater.com/p/10010695/du...id=20539275859
in all seriousness, it is a waste of time.....
https://my350z.com/forum/intake-exha...-for-350z.html
I should end this before it gets ugly.
Seriously OP, TB spacer does nothing, get a plenum spacer.
on
And I put on a plenum spacer on once melted my engine harness. Luckily I had a carb I just bolted to the intake mani til I could install a new one.
Votex-Normal-Vortex. I figured the venturi effect would come into play by doing this, but I was wrong.
The carb is a great idea. I think a slant-6 carb has a pretty close bolt pattern to the intake manifold...just bore out the bolt hole a little bit. I'm assuming you would have to lower the jets not to run rich
Time to end this
11-09-2020 10:27 AM
04-04-2016 07:52 AM
