mishimoto vs champion radiator
on
my radiator is leaking and I am choosing between the two. mishimoto or a champion radiator. my car only has a bolt on but I have a nitrous oxide that I use once in awhile.
the mishimoto have 2 rows and the champion have 3 rows I did do some research and its a mix review between the two.
if your only going to choose between the two which one do you think is better?
any good or bad experience with them?
Mishimoto is great, never a problem with mine
i have the mishimoto on my car. i live in southern az where the temp hits over 110 degrees in the summer. Never had a problem with the radiator. Now the fans they suck. They are complete crap. I swapped out the fans with 2 12'' spal mpl fans and in stop and go traffic with the ac on full blast in over 100 degree weather the cars coolant temp doesnt go over 190 degrees.
on
thanks for the reply and advice I think im going to get the mishi but also when im browsing around I see a mishimoto thermostat have anyone of you also try it? my stock thermostat is still working good do you think its going to be a good upgrade or should I just stay with the stock? by the way is mishimoto made in the USA?
Vendor - Former Vendor
Hey guys,
Thought we should chime in here! Thanks for all of the kind words regarding our aluminum radiator! It is always great to hear positive feedback.
Regarding the comment on our fan quality. We have recently significantly improved the quality of our fans in terms of both reliability and airflow performance. Check out our listing for dimensions and CFM on the new line of fans!
Fan Specs
Fan Specs
xirtam
10-03-2015 02:06 PM
