Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Another LS Build
Old 05-26-2014, 11:28 AM
Classy
Classy's Avatar
You are going to make me start looking at no rotors again aren't you... This is making me want to try and build another car
Old 05-26-2014, 12:57 PM
armt350z
armt350z's Avatar
Haha, I'm not making you do anything, but I will give you a thumbs up for doing one.
Old 05-26-2014, 04:49 PM
350zsunshinefl
350zsunshinefl's Avatar
I am pretty sure this is the first nismo world wide to be LS swapped, usually it is beat up 03's getting swapped.
Old 05-26-2014, 09:43 PM
armt350z
armt350z's Avatar
To me, the nismo chassis is the ideal platform (in regards to Z's) for the swap. The stiffer chassis, the brembos and functional aero just make sense.
Old 06-01-2014, 12:01 PM
armt350z
armt350z's Avatar
I finally got some time to work on the car, my weekend has been made.
Unfortunately this won't be the most interesting post, its all wiring. I spent most of the day tearing the interior of the car apart to remove the autopage terrorist alarm system from the car that the original owner had put on. The installer did not make it easy on me at all on this, there were pieces EVERYWHERE.
but at the end of the day I got the rats nest of crap out.
So on to actual progress...
The most daunting part of this swap for people is likely the wiring. I'm going to try and point out as much of it as clearly as I can for whomever may want to try this later. Note that this is an 08 so plugs, wire colors, and some components may have changed throughout the years.
First this I did was the cooling fans. Nissan uses the IPDM ecu to turn on the factory fans by supplying a ground to the relays. The GM harness and ECU I have suppliers a 12V, and a single 30 amp line at that. You're left with two wiring choices here, you can either add a second 12v 30A circuit from the GM side, or wire into the IPDM and use the Z relays and wiring which is already present. I chose to use the Z relays which meant I had to make my 30A 12V line turn into a ground. I removed the 12v source to the GM relay and put it to ground instead and then ran that to the 3 Z fan relays.
Since my ECU can only handle single speed control, I have to make all 3 Z Relays come on when the GM ecu commands the fans on. In the IPDM the relay in my hand is what your looking for, all 3 are removed in this photo.Name:  2FB23747-6776-44DF-8C2E-7E0868ECF394-1023-000002935155B94B_zpsd4dcf98f.jpg
to run There were a couple options to get the switched ground to these but since the lines from the IPDM ecu to the relays did not provide adequate room to splice into, I had to get creative. I made a small cut into the ground side of each relay and then ran a wire to the contact and soldered it to the IPDM side contact. On the 08 years the ground side is on the right as you look at it.
Here is the cut in the relay
What the wire will look like after its run through the cut
And then what it looks like when its soldered to the contact, you can see the 2 below are done, the top one is left open so you can see where its soldered to.
When the GM ecu turns the fans on now, it will send both stock fans into full high, its not the perfect solution, but will work up until I get a fan controller.
The next post I'll work out the starter solenoid wiring and charging system.
Old 06-01-2014, 02:05 PM
mkiv20vt
mkiv20vt's Avatar
Nice!
I "finished" my LSx swap not too long ago. Fueled kit right? Looks good so far!
Old 06-01-2014, 02:08 PM
mkiv20vt
mkiv20vt's Avatar
Instead of using the IPDM, you could have done a separate relay to trigger the fans with the GM PCM fan control wire. This is the route I went and seems to work well. Basically a fused + source from the battery, ground, and PCM fan control wire. Just food for thought and a lot less work!
Old 06-01-2014, 08:59 PM
armt350z
armt350z's Avatar
It is already done and really was not too invasive. It was either run 2 new fused lines like you said or just run the ground wire through a relay, I think both are actually about the same amount of work.
Old 06-03-2014, 11:00 AM
94z28joe
94z28joe's Avatar
Wishing I would have swapped my LSX from my camaro into my Z now instead of buying a vortech
Old 06-08-2014, 09:14 AM
armt350z
armt350z's Avatar
This weekend was spent finishing a majority of the wiring. The charging system was done and that was as simple as taking a 6 gauge wire and running it from the post on the back of the alternator to the post on the fuse/relay panel.
After that was the starter. Run a large gauge wire of the pos batter terminal to the heavy gauge pos post on the starter. After that run an appropriate sized wire to the starter solenoid from the IPDM or the connector next to it. I used a 10 gauge for the solenoid, crimp on a female spade connector to one end and a terminal lug to the other. Connect the spade connector here:
After that the wiring minus the gauges is done. So I moved onto the intake. Its based off a Camaro SS K&N unit, I just had to cut about 1 and a half inches of length off of it.
I'll start putting the front end back together next and hopefully the differential arrives from Z1 performance soon so I can get the differential back in. After that its simply welding up the exhaust and it will be street worthy and CARB legal.
Old 06-08-2014, 12:09 PM
Classy
Classy's Avatar
I am excited to see this concluded, it is by far the fastest swap in My350Z history.
Old 06-08-2014, 05:21 PM
ConradoR
ConradoR's Avatar
Great progress.
What are the advantages of going with a krc ps pump? My ls6 came with no ps pump and im debating whether to get an used ps pump or the krc one.
Thanks
Old 06-08-2014, 09:42 PM
armt350z
armt350z's Avatar
This pump is flow adjustable via a swappable flow restrictor valve. On the track I like to have very little steering assist, on the street and especially in parking lots I prefer a wee bit more.
Old 06-14-2014, 06:46 AM
350zsunshinefl
Wait, do you live in germany?
I would be pretty excited if we could get an autobahn LSz video!
I might have missed it but what did you do with the diff?
Old 06-14-2014, 12:54 PM
armt350z
armt350z's Avatar
I do live in Germany and will get a video for you when she is up and running. The diff is going to be a cusco unit.
Old 06-21-2014, 02:01 PM
350zsunshinefl
update?
id also like to suggest to change the differential and subframe bushings, with that new added power I think the old silicone filled bushings might not stand up for long, when they fail the silicone comes out and makes the car feel like it has no bushings.
Old 06-21-2014, 02:14 PM
armt350z
armt350z's Avatar
Check post 11, the bushings have already been done. As for the diff itself, I'm awaiting the cusco unit I purchased from Z1 auto.
I've gotten some work done I just havent had time to snap pictures of it all. Whats done so far:
-finished the coolant system
-fuel pump replaced
- Drivers side Cat has been hacked up and welded so it mates with the exhaust using a v-band clamp.
-wiring and gauges are still in progress.
Old 06-21-2014, 05:18 PM
  #38
350zsunshinefl
nice, cant wait to see top out on the autobahn,
are u gona take it to nur ring as well?
Old 06-21-2014, 07:48 PM
  #39
ksuberk54
ksuberk54's Avatar
I will take that vortech off your hands
Old 06-22-2014, 12:43 AM
  #40
armt350z
armt350z's Avatar
I've got just over 300 laps on the ring,
Here is from the mazda just before differential #1 went out, you can hear the whine.
Quick Reply: Another LS Build
