Can a lightweight flywheel cause a loose crank pulley??
I have had my act streetlite flywheel for two years now and two springs in a row at almost the exact time my crank pulley has come loose. The first time I thought that since I'm a newb I didn't torque it right. So I torqued it to 35 ft lbs +60*. That was about a year after I installed it. No problems for a year. Today I heard the chirping sound again and knew what it was. Sure enough it was loose again. So I torqued it again to spec. But I fear someday this is gonna cause my pulley to wobble and shear off the little key in my crank. That's worry some to say the least.
Any ideas?
Any ideas?
Aluminum crank pulley? If so, read into them a bit .
Terrasmak- stock crank pulley
I did get the locktite advise from a local engine guru. Big block Chevys though. Kind of a different animal. I'll try that with a new bolt. Thanks
11-09-2020 10:27 AM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
wanderingstuden
01-28-2016 07:03 PM
