Help?! Rebuild, New, or fix engine??
on
I have a 2003 Nissan 350z automatic touring edition and it's been leaking oil for a while now. I got a mechanic to check it out he said it could be the head gasket seal or the head. I'm not to mechanically inclined so not really sure what he's saying. But anyways, the car has 132k miles on it and I think it's time to change the timing chain too so looking at the "repair cost" what do you think I should do? IMO I want to rebuild the motor but not sure, also thinking about buying a used motor with low miles and just swapping it out. Any help or opinions on what I should do?
id say get a new one, you say you want one with low miles, and at 132k youll fix that and start having other problems, id say just get one with low miles or buy a built block, a couple of the vendors here sell them, and if your heads are fine use those, or buy some with low miles if you plan on boosting..
if you dont have the money for a new engine then the answer is obv, fix what you have.
on
on
If your car is leaking oil, you do not need to replace the head gaskets. That doesn't even make sense. Now, you probably DO need to replace the valve cover gaskets. That is not a $1,000 job. It is rather labor intensive, but not nearly as bad as head gaskets.
You also do not need to replace the timing chain. That is the best thing about them. They do not have service intervals like timing BELTS do.
Sounds like this mechanic is trying to F you over. I would try to find a different mechanic. You definitely do not need a new engine if it is just leaking oil. Now if it were white smoking on start-up and eating anti-freeze, that is a different story.
on
Anyone know of a reliable shop in the miami area? I don't really trust a lot of the shops down here because they do sloppy work. Also for the person who asked I don't want to go FI. I want to just stay bolt on but I don't want to invest the money on upgrades if the motor is going to end up failing.
i would try horsepower logic, they do a lot of aftermarket work and seem to be a good z tuner shop, so i would trust what they say.
350Z_Al
10-29-2020 07:44 PM
