Kinetix Velocity Manifold install problem
Did you try actually resetting the Ecu? Not just disconecting the battery but where you have to hit the pedal a few tines turn it to on and hit it some more and stuff? It's a long process I can try to find the link on mobile and post it here if you need. If not it should be in one of my threads of when I changed my plenum
Here's the link
http://www.technosquareinc.com/350reset.htm
Here's the link
on
Did you try actually resetting the Ecu? Not just disconecting the battery but where you have to hit the pedal a few tines turn it to on and hit it some more and stuff? It's a long process I can try to find the link on mobile and post it here if you need. If not it should be in one of my threads of when I changed my plenum Here's the link http://www.technosquareinc.com/350reset.htm
Hey guys I just installed my kinetix velocity manifold tonight and all went real smooth with the install. The problem came when I went to start it up. At first it fired right up but then idled very rough and gave off a terrible smell so I turned it off. After that every time I went to start it, it wouldn't turn over completely. Like it would lock up or felt like there was too much pressure. Any ideas on what's going on? Thanks
08-06-2021 06:19 AM
