Manual trans what gear when parked?
Old 09-12-2014, 07:45 AM
Suffolk350z
Suffolk350z's Avatar
Default Manual trans what gear when parked?
I know stupid ? bur haven't had a stick in years what gear you guys leave in when parked don't want to wear out sycncrios on first gear.
Old 09-12-2014, 08:04 AM
Junkster
Junkster's Avatar
I normally leave it in neutral with the ebrake on. But then again i never park on hills or anything, if i do i just put it in first...not sure it really matters what gear to be honest.
Old 09-12-2014, 08:05 AM
soc_monki
soc_monki's Avatar
first...reverse if the nose is pointing downhill.
Old 09-12-2014, 08:12 AM
SQuaLZ
SQuaLZ's Avatar
You might regret that one day. Just saying. I did when I first got my Z. The e-brake gave out and I rolled into my friend's Jeep. It was the slightest hill so barely any damage, just dents from his front license plate bolts.
To the OP. I usually either park in 3rd or reverse. Usually 3rd, and reverse if the front is pointing down. No reason for why I pick 3rd, other than it being just the "go to gear" I guess for me since you just push the shifter forward lol.
Old 09-12-2014, 10:14 AM
Junkster
Junkster's Avatar
No i agree, but where i live everything is pretty much flat, the car wont roll anywhere, if there is ever a chance of it i put it in gear for sure. Was it your thread i remember hearing about the car rolling down the hill and a neighbor coming and knocking on the door like dude your cars down the hill in the middle of an intersection or something haha. Or maybe it was someone else?
That was a pretty unfortunate incident lol
Old 09-12-2014, 10:15 AM
bith8791
bith8791's Avatar
I always park in 2nd gear with the e-brake engaged, by the book you're supposed to use 1st and/or neutral I believe.
Old 09-12-2014, 10:24 AM
cashmoney03
cashmoney03's Avatar
Conclusion: doesn't really matter
Old 09-12-2014, 10:37 AM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
Facing downhill, point tires at curb,
" uphill, " " away
Old 09-12-2014, 10:44 AM
Jennifer 2
Jennifer 2's Avatar
Bank robbers and teenagers whose girlfriend’s dad has a shotgun always leave the car parked in first gear for a quick getaway and so should you. First gear gives the engine the most leverage over the wheels to hold the car in place (reverse is too awkward to use) . The synchro unit for first gear barely gets any hard use in normal driving, so it’s one you least worry about. Also, we should always strive for efficiencies in our lives. Jump in, push clutch pedal, turn key, let out clutch and gone escaping the hail of shotgun pellets. Not having to fiddle with the shifter lever on most every start up will save you dozens of minutes over a lifetime. What could be better than that?
Old 09-12-2014, 11:41 AM
Suffolk350z
Thanks got it first gear it is.
Old 09-12-2014, 12:22 PM
350zHalleck
350zHalleck's Avatar
You'd make a fantastic wing (wo)man.
Old 09-12-2014, 02:30 PM
winchman
winchman's Avatar
Use whatever gear has the highest ratio, probably reverse. The higher the ratio, the more force it takes to move the car.
Old 09-12-2014, 06:21 PM
PDX_Racer
PDX_Racer's Avatar
First when facing uphill, reverse when facing downhill (so the engine would have to run "backwards").
That's what I was taught, oh so many years ago.
Old 09-12-2014, 06:39 PM
billydabiller
billydabiller's Avatar
First gear. I like to get in and go.
11-09-2020 10:27 AM
sherm
04-11-2020 05:21 PM
Conway_160
Drag
09-29-2015 08:07 AM
Quick Reply: Manual trans what gear when parked?
