who has a before and after dyno of nwp thottle body
on
i been looking to see if someone ever did a before and after dyno the same day with the nwp throttle body. some say its worth the money some say its not worth.
on
https://my350z.com/forum/intake-exha...e-body-11.html
This is what I found when lurking for that answer. Hope it helps ~
What all mods do you have to hit 261 hp? Most people say you cant hit that with boltons especially in auto, I'm a fellow auto driver so am very intrigued by this. And the v+ is the kinetix plenum right? Also where did you get your tb from I had trouble finding a bigger one when I looked awhile back. And do you have a dyno? I'd really like to see it if possible.
Yeah I won't waste almost $400 on 5mm I'd rather port my own tb for a fraction of the cost.
But at 80-90mm wouldn't you have to get an adapter to connect to the manifold, and port match it to the tb too to be useful?
I could probably fabricate the tb I have to a driveby wire and still be cheaper than thatpodproduct. (i have a 75 mm tb but it wasn't for this car)
I'm switching from the 1/2" & V+ plenum and put on V1 velocity manifold.
Mod list for 261hp/239tq: 1/2"plenum spacer & kinetix V+ plenum, '06 airbox, 3" MAF, cobb intake tube, crawford headers, Z1 HFCs, and Invidia gemini true dual. I loved having the power stay strong up to 6300 and having that as my shift point. If shifted past that, I could tell a small difference.
Dyno
And the TB I have is not an official NWP TB. There's another member on here that found that an infiniti M45 TB is basically the same TB. I think the only differences are the M45 TB has 80mm intake side then tapers to 75mm on the plenum side, and it does not have coolant piping.
M45 TB intake side
M45 TB plenum side
Dyno
M45 TB intake side
M45 TB plenum side
Needs 3.5" or 4" intake with 3.5+" maf to get the most out of the nwp tb or any larger tb.
https://my350z.com/forum/intake-exha...-anyone-8.html
Lots of good info for getting closer to the 300 mark.
In regards to the auto owners, get a new rear diff with 3.5, 3.7, or 3.9 final drive. Best mod you can buy that completely changes the demeanor of the car and changes your butt dyno can instantly feel.
And my COBB hose fits....sorta
Down at Z1 now, but Jon is alitte behind cause apparently somebody has done a hack job on some guys Z32....so Jon's trying to get a good tune on it. And there's another guy in front of me for a tune. Don't know if Jon will be up for tuning with OE TB, then returning it with larger TB. Oh well, I'll see if he's up for it or not.
