HELP! Agency Power Pulley Belt Replacement
Hey Guys,
I need to replace my serpentine belts, except I have the Agency Power Lightweight Pulleys. I have read on several sites that the AP Pulleys are never underdriven as to not effect alternator power, etc and that they're only lightweight. This would indicate that the size of the belts should be exactly the same as stock, so in that case if I was going with Gates belts, they would be part #'s:
K060465 and K040372
However, there's a stock picture on CZP's website that shows the pulleys and the belts in the background, and it looks like the PS/Alternator belt reads part #: K060445, and the AC Belt part # reads K040353 possibly. See below:
I checked out Gates' site, and the sizes on these different belt part #'s are definitely significant enough to make a belt too big/small not fit correctly. I've tried to call AP directly, and they will not provide me with the part #'s for the belts in the kit because they want to just sell them to me for like $75. Does anyone else have these pulleys and can confirm the part #'s I need? I already have a spare set of stock sized belts at home, so if I could use them that would be great. But if I need the shorter belts, then I'll need to order them ASAP. Thanks in advance!!
K060465 and K040372
