engine swap issues, need advice
on
I have an 06 350z, 6sp man. I just bought and installed an engine for it, also a vq35de. I have most everything buttoned up, but this! My old vq has 4 additional sensors 1more at the front and rear of each head. The front ones are on the timing cover/cam gear covers on each side, the rear ones on the inside rear on each head. My new motor doesn't have these plugs. I don't know where, or what to do from here. Please help with any advice you may have, thanks
on
That's the hr...
The revup is a de, except us 350 users classify the 06+ as a revup to tell the difference, IIRC, the difference is the revup has shorter lower runners, not a major difference but I'm sure with newer motors come newer technology, I honestly don't know the answer to your sensor problem but figured I'd clarify on the de vs revup problem.
on
Well, thanks for the expertise on the subject. Now I just need to figure out if I need to install the other (non-revup ) harness and get a new computer, or if I can use what I have and modify it somehow...thanks again
liqalu04
01-02-2022 12:58 PM
11-09-2020 10:27 AM
