Just got JWT clutch and flywheel instal
Old 04-16-2015, 07:09 AM
053z
053z's Avatar
Default Just got JWT clutch and flywheel instal
The flywheel chatters, but that's okay because my exhaust is loud.. The only things I have noticed are it's a very difficult clutch to use, and extremely sensitive. Alot harder then oem, and very tough to push in and sturdy. The catch point has gotten a little higher, since the first day it was installed. It started very low, now its mid-high. In only 100 miles or so. The pickup on speed (to only 3500-4000 rpm at most because of break-in) feels quick, but obviously i have yet to punch it. It also made my old 3rd gear grind mostly go away! Great item so far!
Old 04-16-2015, 12:03 PM
Z33Garage
Z33Garage's Avatar
Its called "break in period"
Also, gear grind is 90% of the time bad synchros
Old 04-16-2015, 12:16 PM
deliabastian
deliabastian's Avatar
wow that's great congratulations!
Old 04-16-2015, 05:54 PM
m e l l o w
m e l l o w's Avatar
OP you driving a 03 or 04 Z?
Old 04-16-2015, 06:00 PM
travlee
Master
travlee's Avatar
Received 9,043 Likes on 6,509 Posts
op probably just had to google that....
Old 04-16-2015, 10:16 PM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Don't think I took my to redline in the first 3 gears for at least 2.5 miles after mine was installed. Just drive it, I still have mine , 120k miles later.
Old 04-17-2015, 03:46 AM
jdm-v35
jdm-v35's Avatar
If you really have a hard time driving it buy an RJM clutch pedal. It will definitely help. The JWT combo should be a walk in the park to drive though.
Old 04-17-2015, 06:43 AM
Zmandriving
Zmandriving's Avatar
op I hope you did Slave and master cylinders. You will have to replace those after about 10K miles with jwt combo. It happened to me when I had my my jwt kit installed. I don't think it will be that much work because I think your slave is external instead of internal like mine is on 07 hr.
Old 04-19-2015, 06:18 PM
Frank_White
Frank_White's Avatar
i was always told the jwt clutch feels really light
07-10-2022 07:44 AM
04-22-2021 09:42 PM
11-09-2020 10:27 AM
Quick Reply: Just got JWT clutch and flywheel instal
