2006 350Z slip light
on
Hello,
I own a 2006 350Z and am having a recent recurring problem with my slip light coming on and a shuddering in the rear on right hand turns. At first it was not so frequent and now occurs all the time. Is my ABS activating through the traction control computer, or? Any advice is VERY welcome !!!
Jamie
p.s. I've been to the dealer twice and it doesn't spit out any codes and they consider this a ghost problem/ non-issue even though I am afraid of spinning out in corners at normal non-agressive speeds...
Jamie
General & DIY Moderator
Welcome- this does not sound like a ABS problem. The slip light comes on when the ECM detects one wheel spinning and losing traction. If it's during right hand turns, it could be the RR tire is lifting and losing traction. If you are driving a base model, it could be the open diff is simply spinning the tire and your TCS system is operating normally.
on
Yeah, but same driving same corners and now slipping after 10 years...doesn't seem like loss of RR traction only...if so could it be spring rates are worn?
What is the condition and sizes of your tires?
xirtam
10-03-2015 02:06 PM
