03 350z differential fluid?
Hey I have a 2003 350z BASE and its time for a differential fluid change, what fluid do I need to use? It does not have an LSD, just an open diff...sadly... please lemme know what fluid I need...thanks
350Z/370Z Tech Moderator
Capacity is "about" 1.5 qts (same between either diff) but how much goes in after draining depends on your method (on the bench/opened up or pumped out). Either way, you'll end up buying two qts and filling (while car is level of course) until the new fluid starts weeping from the drain/fill plug hole.
xirtam
10-03-2015 02:06 PM
