Cricket/Chirping Noise Coming From Engine
on
hey guys i recently had a problem with my Z making a chirping/cricket noise, so i went ahead and replaced both belts to OEM nissan. When i started up the car i had no noise so i figured it was fixed, but i drove it around and when i came back home the noise came back when it idled.
Usually the noise happens when I come to a stop, the noise will go away if i rev the engine.
the tension on the belts should be good, i followed the specs on the thread on here with 5mm deflection on the bigger belt and about 10mm deflection on the thinner belt.
Although usually these type of noises come from the belt i felt like when i popped the hood it was coming from the back of the engine (towards the firewall) but i could be wrong, the old belts were pretty trashed though.
Anyone have an idea of what it could be?
I have been hearing a similar sound. It only happens when its cold or when I haven't turned on the car in a long time. It doesn't stay on though only on startup.
on
Thanks for the reply guys.
If it's the pulleys would it be normal that changing the belts made the noise dissapear until I drove it for a few miles?
on
Kenny, if you look at an online copy of the factory service manual you will see that Nissan provides two different tension specs. One is for tensioning an existing belt that has been in service for sometime, and another tighter one for installing new belts on pulleys that have some miles on them. What you are experiencing is quite common. The groves on the new belt wear into and seat a little deeper into the pulley groves. This is an expected ‘break in’ process for the new belts and they need to be retightened as they have lost some of the tension you set them at.
I can’t remember the exact method we used when setting the belts on my car, but it entailed pushing a set amount of force to the top of the belt run and then measuring the amount of deflection. I can look it up if you if are unable to find it.
First check out the longer of the two belts as that one is most likely to chirp /squeal as it is driving more accessories.
on
Kenny, when you hear hoof beats, think horses, not zebras. Even the mechanics here (which I’m not one of) cannot fix your car over the net; they can only give you a list of the most probable things to check first. If you hear some squealing sound in addition to the sound of crickets (especially with the first cold start of the day) it would indicate the new belt has lost some tension and needs a second tightening. If there is no hint of belt slip/squeal then check the bearing in the idler pulley (on the top of the larger belt) for roughness and excessive side play. My bet is on simple belt slip though.
on
hey guys sorry to bring up an old-ish thread but i ended up tightening my belts and the noise is still there, and once again only when i rev past 1000k rpm the noise goes away. Im guessing its my pulley bearings, can anyone link me a site of which part it is, or a part number for the pulleys
thanks!
thanks!
You have to find out which one it is first. Either use a mechanics stethoscope to isolate the noise or you can just remove your belts and inspect each pulley individually. The culprit will will probably be obvious (roughness and excessive axial play) but as i said it may also be your ac clutch. If the noise changes or goes away with the ac compressor engaged then it may be worth investigating, but that sometimes happens when a pulley fails anyway so isolating 100% can be tricky.
on
I just started hearing the cricket noise the other day on my 2003 350z. The noise is there on start up but goes away after about 3 to 5 mikes of driving. I put on new belts in the spring so I'm going follow Jennifer 2's advice and check the belt tension. I will post the results.
Results from belt inspection "chirping noise"
After completing the oil change task I inspected the belts and pulleys. I found the 14mm nut that secures the main idler pulley assembly was loose. I adjusted then tightened both idler pulley assemblies chirping sound is gone.
The chirping noise came back. I was able to trace it the ac idler pulley. With the car running I was able to adjust the tension until the noise went away. In my case the belt was too tight.
General & DIY Moderator
That's an excellent point! Overtightening a belt will also cause problems and is almost as bad as not tightening it enough. Using the FSM method of checking belt deflection is a good way to ensure you're getting it just right.
Water pump failing. Had it happen on my 2009 jeep wrangle when it was only 2 years old. It's a chirp sound that happens every few seconds or so. Kept taking it to the dealer and they kept trying other things, when I told them it was coming from the water pump. Finally they gave in and just replaced the water pump after I botched for about 3 months. Guess what I was right never made the noise again and the mechanic said they were sorry they didn't listen to me sooner. Even the GM of the dealership apologized. He asked my how I knew it was the water pump. Told him it took screw driver and stuck it up to my ear and touched the other end of the screw driver to parts of the motor till I could here the sound. I was F***ING pissed that it took them that long to do what I told them to do.
liqalu04
01-02-2022 12:58 PM
08-06-2021 06:19 AM
