High Oil preassure on cold start
on
I own a 350z 2003 (Imported from the US, if that matter).
However, when I start the car the oil preassure stays at 100 PSI and stays there untill the car gets warm enough then it falls to 30 PSI and with full throttle it goes to 110 PSI ish.
I've attatched a external oil preassure sensor and it shows that it is high on cold start so it is not a faulty gauge (sp?).
Anyone here got any ideas what the hell is wrong with my Z?
on
Thanks for that info. However, I will probobly keep being paranoid about that damn oil preassure though.
Yeah. It starts at 100+ PSI. Is there any risk of having the car reach 120 PSI? Or shall I just drive it softly untill it heats up?
Pressure is a measure of restriction. Cold oil is thicker and thus harder to pump ergo pressure is higher. Completely normal. I'd be worried if it doesn't go high when it's cold more than I would be the other way around.
