my tcs and slip light on
Old 09-29-2015, 12:21 PM
loudtoyz
loudtoyz's Avatar
Default my tcs and slip light on
when i turn on my car the tcs and slip light comes in two second after. this cause my car to lose power. What could possibly cause that?
jtanabodee (05-26-2022)
Old 09-29-2015, 12:37 PM
travlee
Master
travlee's Avatar
Received 9,043 Likes on 6,509 Posts
what size are your wheels and tires?
Old 09-29-2015, 12:40 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,290 Likes on 894 Posts
Welcome- one possibility could be damage to a wheel speed sensor that is causing the TCS and slip light to be activated. Any changes or problems you've had recently that preceded this problem?
Old 09-29-2015, 04:40 PM
pr_350z
pr_350z's Avatar
most common cause of this would be the camshaft position sensors, they turn those lights on and throw the car into limp mode(thus limiting power). my suggestion is to take the car to autozone or wherever you can get your "codes" read for free, then if you see that codes point out the problem to be a camshaft position sensor, search on ebay for BOTH OEM sensors(left and right, they usually go out within a couple months apart from my experience), dont buy cheap replacements as they are usually a waste of money.
DougEvans (05-02-2021)
Old 09-29-2015, 05:35 PM
travlee
Master
travlee's Avatar
wait, what.... hate to burst your bubble, but you are wrong
Old 09-29-2015, 05:55 PM
HRMoneyPit
HRMoneyPit's Avatar
Yeah what tire sizes
Old 09-30-2015, 03:48 PM
RWDBajan
RWDBajan's Avatar
Tire size will not turn tcs and slip on at start up. You have to drive a bit first. I know this because my rear tires are wrong and it takes 20 minutes to turn the lights on, and there is no power reduction either. I'd go with a damaged sensor. Maybe got hit by a rock?
Old 04-05-2023, 04:47 PM
aiko.z33
aiko.z33's Avatar
Can spacers have an effect have oem wheels tire size just 1.5 spacers on rears only
Old 04-06-2023, 04:52 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,054 Likes on 744 Posts
Spacers will not cause a fault because they do not alter the circumference or overall diameter of the wheel and tire.
Uriyo_
09-08-2021 08:46 AM
10-04-2015 07:55 PM
350z82
10-01-2015 06:25 PM
Sleeper_Z
09-30-2015 10:25 AM
samansharif
09-25-2015 12:31 PM
Quick Reply: my tcs and slip light on
