Replacement for an OEM clutch
on
So I bought an 06 350z about a month ago and everything's been going smooth, but the clutch needs to be replaced badly. When it's anything under 65 degrees outside my clutch won't disengage all the way and it's next to impossible to put it in reverse without letting it sit at idle for a few minutes. It also slips like a mother f###er.
So I took it to a mechanic and the dude quoted me 900 for an OEM clutch kit (without the flywheel) with labor included. The clutch kit he found was around 450 so it's not bad.
"But why is this idiot making a thread about it?" you might me thinking.
Well f### you, here's why.
I'm looking at getting a mild aftermarket clutch kit instead of the OEM one, and I wanted to get some opinions on my picks. I'm not looking to get anything too crazy and I live in LA, so I don't want anything more heavy than a stage 1 clutch. My car's all stock except for the exhaust and I'm planning on keeping it that way, so I don't need to support more power or a turbo set up any time soon.
Here's what I'm looking at:
Exedy:
Z1 mild clutch:
https://www.z1motorsports.com/z1-pro...it-p-3052.html
I've been hearing a lot about the JWT clutch and flywheel combo, but I'm not replacing the flywheel and i haven't found the clutch kit by itself for sale.
Let me know what you think, and suggestions are more than welcome.
Here she is with the v1 rep spoiler that's gonna disappear soon.
Exedy:
Z1 mild clutch:
350Z/370Z Tech Moderator
edited........
edited........
They're available a la carte from lots of vendors that sponsor this site. Here's one....
https://conceptzperformance.com/Cart...ion.php?II=323
on
yeah, getting a new flywheel would be the smart thing to do, but my wallet doesn't exactly allow for it right now....
Are the other clutch kits i linked out to garbage compared to the JWT clutch kit? and would you guys recommend the JWT clutch for daily driving over OEM?
on
To my understanding a flush could help with the shifting in cold weather and give me a more consistent engagement point, but the main problem is the gear slipping. Corollas are passing me at green lights cause of the slipping lol.
So, are you saying i should just bleed the clutch fluid and wait until I can afford a clutch and flywheel?
I bought the same Exedy clutch and had the dealer fit it to my 03 about 3 months ago. No issues whatsoever. I have about 85k miles on it (car, not clutch). Didn't change the flywheel either. Why spend double the money if you're not adding power or tracking the car?
because its best to do it all.
I plan on clutch, flywheel, Master and slave next year. A long with a 50/50 mix of Redline and Motul in the trans cause my 100% Motul is meh and i RJM told me a mixture would help. Motul is fine but getting into gears for the first couple miles is pretty bad. Once warm its all gravy
I would probably grab this if it's in your budget https://www.z1motorsports.com/z1-pro...bo-p-2405.html
Now for the JWT thing, believe it or not, the JWT clutch is an Excedy organic. Same clutch. I had JWT the first time, now Excedy in my car.
on
So would you recommend the z1 motorsport clutch kit over the exedy one? the price is very tempting on the exedy clutch kit
[Edit: Is it a pain in the *** to change the clutch myself? If i can do it I'll be able to afford a flywheel]
Swapping it yourself. You need a tall set of jack stands. I use my motorhome stands. You will need the jack to get the car up that high. You need 2 people to drop the trans if doing it on the ground. Can be done, I just put mine together again.
