lsd swap to base model z
on
i currently have a base model z with an open diff my friend is selling me his oem lsd for 300 has 85,000 miles on it. if i do swap it is it just a direct swap? like just remove the open diff and put the new one in? and do i have to change my gears? what would happen if i didn't
Don't pay over $200 , if you want to spend $300 , grab one from a 370Z
Don't.
By that many miles it's just as open as yours
Changing the diff only requires checking and aligning ring & pinion.
OEM's LSD diffs are viscous ones, better save money for torsen / clutch type LSD.
6 inch cawk is my fave!
I would hope for $300 you are getting the entire pumpkin with new bushings... A real friend would just give you that ****.
I thought this thread was going to be a build thread about and ls engine haha epic fail
