Things to replace/mod while doing a clutch change
Old 04-10-2016, 11:25 PM
#1Pussologist
#1Pussologist's Avatar
Question Things to replace/mod while doing a clutch change
So I just received my JWT clucth/flywheel combo and I'm having it put in on thursday. What other parts would you recommend replacing or upgrading to accommodate the new clutch and keep my baby running strong.
I'm at 93k
Thank you
Old 04-10-2016, 11:58 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
I'm at 93k
Thank you
Presume you got pilot bearing, pivot bearing, slave cylinder, S/S hose if you got the full kit, yes?
Old 04-14-2016, 04:09 PM
#1Pussologist
yes full kit,I don't think it comes with a slave cylinder
Old 04-14-2016, 04:52 PM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
i would do master and slave.... then you will know everything is done. just my thoughts
Old 04-14-2016, 09:30 PM
dcains
dcains's Avatar
You didn't say what year your Z is, but if it's got the HR motor, don't even think about not replacing the master and slave. If the slave fails in teh future, the trans would have to come out again. But, even with the DE motor, I'd replace all the hydraulics, and as Trav said, you'll know it's done and you won't have to worry about it for a long time.
Lithg
06-23-2016 06:48 PM
Chris Moody
04-17-2016 03:52 AM
cincysilvias14
04-07-2016 07:13 AM
Quick Reply: Things to replace/mod while doing a clutch change
