slipping clutch.
slipping clutch.
04 350z manual.
so im having like a power issue.
when im driving or when i start up from a stop, it takes awhile for the trans to catch with the engine and actually go with a bit of power. when i step on the gas at a higgher speed and higher gear it revs up before catching and actually going faster.
i havent had a chance to do any diag, but a few older tech friends of mine suggested that the clutch is slipping. but then started talking about resurfacing the flywheel and such. i was confused because i work at monster transmissions and assumed when they said clutch is slipping it meant the friction clutch plates in the trans were worn. can anyone shed some light on this for me?
if it doesnt sound like "slipping clutch" could anyone point me in the right direction?
Thank you in advance.
It's got about 117k on it right now, I've had it since about 60k.
And I would but we don't deal with foreign transmission or manual so I'd be kind of lost in that aspect.
The JWT flywheel/clutch combo is a good choice for an upgrade. You'll get some more noise from the lightweight flywheel.
The mechanics of a manual transmission aren't too complicated. This may give you a little guidance:
As far as install, if you can follow the procedures in the FSM or this link (https://my350z.com/forum/engine-driv...wt-clutch.html) then you'll be fine. If you have access to a lift, then it will go much smoother.
ThomBoh
Southern California
06-01-2016 03:23 AM
