Clutch/Slave Cylinder Question
Does anyone know how far the slave cylinder is supposed to move on a 04 G35/350Z.
I just installed a new Wilwood master cylinder to see if I could finally get my clutch to disengage but that didn't happen. I bleed it with a clear vacuum tube on the bleeder valve to see when I stopped getting air bubbles. I'm no longer getting air bubbles and I have a good feeling clutch pedal but my clutch will not disengage.
Could some one measure how far there slave cylinder moves there fork on the out side of the transmission for me?? Please and Thank You.
Vaccum pump won't get it,collapse the slave cylinder with a c clamp(easier to do with it unbolted from the trans. Have someone help pump the pedal, just like doing brakes. Once the pedal is hard, bolt back onto trans. A few more pumps and should be golden.
Conway_160 (09-07-2016)
It all started when i pulled the motor out the final time. It just stopped disengaging, im pulling the clutch all the way out friday to see if welded together on the first start even though i didn't smell anything.
Also the spacer is just for trouble shooting it will be removed froday.
