Not going into gear after engine swap! Please Help
Hey everyone I just got done swapping the engine in my 03 for a lower mileage better condition engine. Process went smoothly until the very end when the new engine was first turned on the car was still on jack stands and the wheels started rolling. I was confused and confirmed the transmission was in nuetral, it was. So I next attempt to cycle the gears, first gear went in ok then NOTHING after that. 2,3,4,5 and 6 gear all not there, noise comes from under car when you try to press into the gate. Big factor I changed the stock clutch line for a Z1 steal braided and my clutch pedal feels weak, tried to conventionally blead clutch 4 times and nothing changed; no visible leaks. When the car is off you can cycle all six gears and reverse clutch in or not. Very confused not exactly sure what to do next have been told master cylinder or slave but both worked perfectly fine before new line and the swap.
POSSIBLE FACTOR:
Engine replacement was pulled from 5AT Z, removed auto pilot bearing and installed manual pilot bearing.
Replaced clutch with stage 2 and flywheel for single mqss
Clutch will not conventionally blead.
THANKS FOR YOUR HELP
POSSIBLE FACTOR:
So update, adjusted the clutch pedal to engage higher and started car in second gear. Somehow something worked and the car will now go in all gears while on, progress. BUT the clutch is grabbing seriously close to the floor like maybe an inch, and this is after the adjustment which was three full turns of the adjustment rod. Have read the clutch still needs to be bled more to help with engagement. Any idea about this? I'm just happy to know the problem isnt looking as internal as before. Thanks for your response I appreciate your time and knowledge!
Make sure you bled it properly, and then keep bleeding.
And if it stays that close to the floor, you are lucky. The engagement point will come up, characteristic of the platform.
As long as you were able to close the bellhousing (no gap) and didnt mess us on the install, and used the correct parts, its the bleed or master/slave cyls.
