De loss of power need help!!!
on
I rebuilt my 2003 base de by a local respectable machine shop.
My car after 1700 miles or so wont let me pass 4k or even sometimes 5k in any gear it feels like i have no power what so ever and the car sounds different. No codes and if i keep it at 4k a random misfire code comes up. It begins t bog out when stuck at either 4k or 5k but its weird because its been happening withing 2 weeks and it would randomly be fine then just driving under normal condtitions start to bog and act funny. I hate/love my car i need help
yes my fuel pressure is within spec physically took the fuel pumpm out and inspected it and the lines
compression tested both wet and dry ranged from 180- 190 dry 205-215 wet
changed my maf cleaned twice
changed my coilpacks and sparkplugs ngk iridiums gapped to spec
changed an 02 sensor
i have hollowed out cats with bungholes for the 02 senosrs
checked connectors from coil pack there fine check tps connector seems fine
used scan tool to look at ignition timing pid while driving to monitor knock sensor and it didnt pull timing when bogging out happend.
Clutch isnt slipping at all new clutch when swapped in motor
campostion sensors new.. New crankpostion sensor new. Starter works fine new alternator nothing with ac is hooked up because shot bearing and couldnt stand the noise. Please help i cant figure out my issue
rebuilt motor .30 over
replaced guides
vlave job
resurfaced heads
celan/polish crank
new connecting rods new main bearings new thrust washers new pistons new piston rings new head gasket and engine gasket set new oil pump new main seals.
replaced guides
vlave job
resurfaced heads
celan/polish crank
