Position of 5th gear changed after Transmission pulled to replace Clutch Slave
Old 12-13-2016, 05:13 AM
KS0385
KS0385's Avatar
Default Position of 5th gear changed after Transmission pulled to replace Clutch Slave
I had to replace my slave cylinder last week. Fifth gear is in a different spot now. I used to be able to move the shifter all the way to the right then up for 5th. Now it's not all the way right but a bit away from the end.
What could have happened? Is it a big deal?
Old 12-13-2016, 06:50 AM
knuckles899
knuckles899's Avatar
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/477784-shifter-re-alignment.html
Check this out, it may help.
