Transmission noise
Transmission noise
hey guys I've researched and researched and I'm about to buy a new clutch and flywheel for this reason. I have an 04 with 38k miles and the transmission makes a weird noise, like a scratchy spinning. should I buy a new clutch based on this noise? It's more prominent when clutch is not pushed in. Thanks for input.
350Z/370Z Tech Moderator
And, how is the clutch action/engagement?
I'm betting "Yes" and "OK", respectively.
If so, it's normal. The Nissan tranny (from gear and input shaft noises) isn't particularly known for being quiet. It a lot more prevalent with the later HR-specific CD009s but all of them are like that. When you step on the clutch, you're putting pressure on the shaft that quiets it down. Kind of like putting your finger against a small bell to quiet it.
If your clutch feels good and you have no gronking while shifting, just leave it alone.
