Transmission fluid question
I recently ordered redline mt90 and i keep seeing people say you shouldnt use it and others saying you should. Should i cancel my order or just use it? Will i be harming my transmission using this fluid?
I think any good trans fluidity rough in the morning. I live in Socal and the Motul I use is horrible the first couple miles. But by then I'm on the freeway anyway
I run Royal Purple Max Gear and its the same: when cold (in FL haha) its hard to get in gear and grinds in 3rd and 5th even after I swapped in a CD009. Once warm it shifts fine and almost never grinds. On the track I have no issues. Been thinking about switching to the Redline 50/50 mix solution.
Just make sure to use GL4 stuff in the tranny.
And reason you went with the MT90 instead of the MT85?
