Radiator Replacement Question
Old 03-21-2016, 08:59 AM
Roubaix46
Roubaix46's Avatar
Default Radiator Replacement Question
Purchased a cheap radiator replacement till I can save up for an aluminum one, and once it arrived I noticed two aluminum ***** on the bottom of it, looks like fluid may drain out of these? Might be a stupid question but what the hell are these? My old stock one did not have these and I don't know what I should do until I know what they are for. And help would be much appreciated.
Old 03-21-2016, 09:19 AM
Zivman
Zivman's Avatar
my guess is you bought a radiator for an auto and you have a manual. those ports look like tranny input/output for a built in trans cooler
Old 03-21-2016, 09:22 AM
Roubaix46
Roubaix46's Avatar
It says it's for either manual or auto. So somewhat confused still, don't know if I'm just supposed to block them off or what
Old 03-21-2016, 09:30 AM
sportbiketed
sportbiketed's Avatar
Its an auto transmission cooler, just cap them off with some rubber nipples.
Roubaix46 (03-21-2016)
Old 03-21-2016, 09:33 AM
Roubaix46
Roubaix46's Avatar
Okay, cool. If I just cap them, should I use a tight fitting cap or will just standard runner nipples work. I don't want anything to leak out of course
Old 03-21-2016, 10:15 AM
canadarob
canadarob's Avatar
its a heat exchanger for auto transmission fluid to flow through the radiator but separate from coolant. Nothing will leak if you do not cap.
But I would cap as suggested to keep corrosion out. The cap wont face any pressure.
Old 03-21-2016, 11:59 AM
dcains
dcains's Avatar
My '08 needed a replacement radiator under warranty. The car is a 6MT, but the dealer only had a 5AT radiator in stock, so I gave them the OK to installed that. I just put some vacuum line caps on the fittings, with a little silicone sealer to keep them in place. No issues after several years.
Old 03-21-2016, 01:42 PM
CK_32
CK_32's Avatar
Nope your fine bud. I literally just bought one of those for my car as well. IIRC those are for a A/T fluid or something.
Mine is a M/T roadster and it runs fine. No leaks or caps needed. My only suggestion is put cardboard over the fins during install or something. I smashed a bunch of fins trying to bolt mine in. Then some more when I pulled my belts off from the wrench breaking loose.
Old 04-01-2020, 03:14 PM
Bdjenk25
Bdjenk25's Avatar
Default Radiator with A/T cooler lines
I have manual transmission can I use the A/ T ports to cool my oil can? It has a radiator hose going to it?
Old 04-02-2020, 10:30 AM
CK_32
CK_32's Avatar
you could try it, but I wouldn’t recommend it until you know it can stand the pressure. All these different fluid systems have different pressure caps. Oil, trans, coolant have higher or lower pressures so one may or may not hold the pressure for the other.
but if you want to try and test it go for it. Just be careful.
Old 04-02-2020, 11:02 AM
Bdjenk25
Bdjenk25's Avatar
Default Radiator A/T cooling ports
Do you know what port is for fluid in and fluid out?
Gs_350z
03-16-2020 03:34 PM
Xsellr8
11-05-2017 10:06 AM
pilotstephen
12-04-2012 03:17 PM
andrew16639
11-30-2008 03:57 PM
NVthis350
06-22-2005 12:51 PM
Quick Reply: Radiator Replacement Question
