Odd 5th gear entry after clutch install
Hey all,
2003 with 145 miles and I got the clutch swapped for a Z1 mild spec clutch and a resurfaced OEM flywheel. I'm getting massive vibrations which im assuming is due to an incorrectly resurfaced flywheel, ordered a new Z1 21lbs to swap it out with.
Anyways, I noticed when i throw the shifter all the way to the right, then up, it won't go into 5th. It goes into all other gears fine but has trouble with 5th. I have to move the shifter about a 1/4 inch to the left then it goes in no problem.
Anyone get this issue before?
