My last Dyno with JWT Cams
Old 01-12-2005, 02:06 PM
  #61
Purple_Peer
Purple_Peer's Avatar
well i took a look into the manual there´s pretty much to read.
im going to print it tomorrow and read it on a sheet im gonna get bussy with the acrobat on the screen ahead...
can i use something like seal-paste instead of a gasket? i think gaskets will coast a little fortune in germany
i going to went to honolulu in march, may i should try to catch up some cams there just out of 16 percent taxes
Old 01-12-2005, 05:13 PM
  #62
Zmego1985
Zmego1985's Avatar
Its called Gray RTV Sealant they sell it at auto stores. This car does not have to many gaskets to replace. Except head gaskets, plenum gaskets, coolant gaskets, and the throttle body gasket for cam installs. These gaskets you can reuse except the head gaskets, but for most cam installs you do not need to remove the heads anyways.
Thanks Glen
04-22-2021 09:42 PM
11-09-2020 10:27 AM
silverbullet_Z
NA Builds
24
11-14-2015 02:52 AM
B Esquire
09-24-2015 07:52 AM
Quick Reply: My last Dyno with JWT Cams
