You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
It doesn't mean that the OEM ecu doesn't record the odometer either.
chances are that it does! It would be simple enough for it to do so. The question is whether the ECU can be fully erased.
I presume you're replacing an engine and want it to start logging from scratch? Either that or you're being a naughty boy!
Originally posted by zuff It doesn't mean that the OEM ecu doesn't record the odometer either.
Ask the TS guys if they know.
Kinda but kinda not. If I do all my bolt ons and then change the ECU and something goes wrong, just like any tuner I would return my car to stock as much as possible and put the stock ECU back in, but now the ECU and odometer does not match and boom Nissan says **** you and no warrenty. Get what I am saying?
Ok, lets say the ecu IS a backup and records the mileage. As soon as I plug the stock one back in, it should backup and record the new mileage. Right? I don't know, but that would make sense to me. Hopefully, I never have to put the old one back in to find out.
Also, I just got a datalogger which senses what inputs are available on each car and odometer is not among them. I plugged it into a friend's Scoobie and it sense the MAP and several different inputs that mine did not have. So I kinda doubt that it does. But who knows. Sneaky little car manufacturers.
Id guess its seperate, reseting the ecu by disconnecting the battery or peddle doesnt erase it either. ecu might reference it for its own purposes; but I think its stored seperate.
mileage is mileage on the car not the engine. so swapping an engine isnt a worthy reason to reset it. you just log when the swap was done and subtract to get the mileage on just the engine.
Originally posted by ares Id guess its seperate, reseting the ecu by disconnecting the battery or peddle doesnt erase it either. ecu might reference it for its own purposes; but I think its stored seperate.
Thats not the reason why I am asking. If I were to one day run all the bolt ons or whatever and a standalone, and say teh tranny goes. First thing is to take off parts so they cant blane my other mods (which they technically cant but will give me a hard time) but if the milage is diff from ecu and odometer then I am screwed. Get what I am saying?
You're also assuming the service guy is even compentent enough or motivated enought to even try matching them up. I don't think that procedure is mentioned anywhere in the service manual, so chances are they wouldn't even think of doing it.
the ecu doesnt hold the milage on the car....that is a myth....it is what service calls burned into the circut board in the back of the gauge cluster......i am not saying this as a guess...it is fact...i order new odometers every day at the nissan dealership im a service advisor at....ecu has nothing to do with milage what so ever
Originally posted by tonylittell the ecu doesnt hold the milage on the car....that is a myth....it is what service calls burned into the circut board in the back of the gauge cluster......i am not saying this as a guess...it is fact...i order new odometers every day at the nissan dealership im a service advisor at....ecu has nothing to do with milage what so ever
Can you provide the part number needed for a 2003 G35c to swap out this chip, so once I change my motor I can replace it.
the actual gauge cluster its self holds the mialge.... when that is change, they only way it can be changed legally, is by having your mialage logged at your dealer, car remainging at the dealer until the new cluster is installed that is pre-programmed with your mialage...
no....as jason and i have both stated the milage is burned into the circut board on the cluster...the dealership orders the board and submits the milage to the cluster manufacturer...the milage is burned into it and then shipped to the dealer....car must remain at dealership until new cluster arives and is installed....
Originally posted by tonylittell no....as jason and i have both stated the milage is burned into the circut board on the cluster...the dealership orders the board and submits the milage to the cluster manufacturer...the milage is burned into it and then shipped to the dealer....car must remain at dealership until new cluster arives and is installed....
hope this helps
hmmm...this is what I hear
"Find wrecked Z with cluster with xx miles, replace your cluster that has xx+10k miles.....the ECU doesn't know about it, your car for all intents and purposes has xx miles now"
This of course depends on service, registration, inspection mileage jiving.
if that really happend he needs to have his odomoter reprogramed... i wouldnt stand for that... he shouldnt either.. getting an extra 10k miles.. not cool...
