Test Pipe SES Non-Fouler Fix... pics
Old 08-08-2007, 01:09 PM
  #81
Pikespeak350Z
Pikespeak350Z's Avatar
how would i go about checkin that, without acutally having to buy a pair of 02sensors? Thanks
Old 08-08-2007, 05:01 PM
  #82
ISMSOLUTIONS
ISMSOLUTIONS's Avatar
Wow---OK...there are a bunch of steps, in checking all 4 sensors...mainly voltage and impedance based, before they get removed.
Process is kind of heavy..and there are not specific troubleshooting steps for this code...but there are other codes that have troubleshooting steps that will help.
I'll dig them out later tonight and post them..
Rick
Old 08-09-2007, 02:16 PM
  #83
VitViper
VitViper's Avatar
What exactly is this "pedal sequence" to reset the ecu?
Old 08-09-2007, 02:19 PM
  #84
Pikespeak350Z
I'll post it tonight if no one does before me, i have it printed out in my car.
Old 08-10-2007, 05:52 AM
  #85
ISMSOLUTIONS
Do a quick search on 'easy ecu resetting'
Old 08-10-2007, 05:54 AM
  #86
ISMSOLUTIONS
o2_checks.pdf
See attached - one way to test the sensors for operation.
Disregard all the code references - the testing is what this is about.
Rick
Old 08-10-2007, 06:43 AM
  #87
RBlover69
RBlover69's Avatar
so , ....question, .is it possible to run the Fast Intentions Res TPs without throwing a Code in the 06-07s Zs...because from what im seeing its like every 06z with tps throws a code with the non foulers, maybey theres something i missed.
Old 08-10-2007, 06:55 AM
  #88
ISMSOLUTIONS
We haven't seen an issue with non-foulers...they have worked every time.
Rick
Old 08-11-2007, 02:10 PM
  #89
Raceism
Raceism's Avatar
Default test pipe toque spec
Does anyone know torque spec for test pipes? I'm installing new test pipes today. Thanks
Old 08-11-2007, 02:35 PM
  #90
ISMSOLUTIONS
Real tight...like real tight...no real torque specs that will matter.
Rick
Old 08-11-2007, 03:49 PM
  #91
RBlover69
RBlover69's Avatar
Rick
lmao....you should put that on a card with them lmao ..
intructions
ummm tight real tight lol
jk
Old 08-11-2007, 04:04 PM
  #92
ISMSOLUTIONS
intructions
jk
I know...but it's true...tighten it really well, not with a breaker bar or anything - but GOOD and tight...tighter than you'd put on a lug nut. Somewhere in the 90-100' lbs. range.
Rick
Old 08-31-2007, 09:23 AM
  #93
VitViper
VitViper's Avatar
Nothing in the code list resembles that code...can't find it, or possible repair and troubleshooting/diags.
Where there any other codes?
OK - found it..
P2A03O2 Sensor Circuit Range/Performance
That's an electrical issue...check it out...might need a sensor..
Rick
I got this same code about 200 miles after I put on my test pipes and anti-foulers. It indicates that the primary O2 sensor on bank 2 (bank 2 sensor 1: primary O2 on driver-side bank?) has a range/performance issue. Did the guys putting on my TP bump the sensor or the harness or some weird ****??? Why would I have to worry about the primary O2 sensors after I put on test pipes lol
Old 08-31-2007, 09:32 AM
  #94
ISMSOLUTIONS
OK - so you answered all your own questions
Question 1 - answer - maybe, is anyone on this thread actually looking at your car now?
Question 2: refer to questions 1
Old 08-31-2007, 09:37 AM
  #95
VitViper
VitViper's Avatar
It was more of a ticked off post than anything. Weird problem for the primary one to throw a code when it wasn't even touched
I am correct in the fact bank 2 is the driver side bank?
Edit: 07 primary sensors the same as 06?
Old 08-31-2007, 09:40 AM
  #96
ISMSOLUTIONS
Yes and yes...bank 2 id drivers side and there are 2 sets on 07's as well.
Rick
Old 08-31-2007, 09:44 AM
  #97
VitViper
VitViper's Avatar
Rick
2 sets of? I know each bank has one before the cat and after the cat, for a total of 4.
Old 08-31-2007, 10:02 AM
  #98
ISMSOLUTIONS
yes...2 sets...1 set on each side.
Old 08-31-2007, 10:16 AM
  #99
VitViper
VitViper's Avatar
edit: Screw it, this is probably 99% the cause of not having cats. It's easier and cheaper to reset the ecu every couple hundred miles than buying new sensors that won't fix it (IE: primaries were never removed during the install of the test pipes).
Old 09-19-2007, 08:22 AM
  #100
Bob Martin
Bob Martin's Avatar
subscribing
Quick Reply: Test Pipe SES Non-Fouler Fix... pics
