Test Pipe SES Non-Fouler Fix... pics
Old 10-03-2007, 11:49 AM
  #101
malized
malized's Avatar
Old 10-03-2007, 01:54 PM
  #102
VitViper
VitViper's Avatar
Originally Posted by malized
hi man .... im happy that there is that article... i buy an APS test pipes 2.5 inch ... how i should make a nice trick to dont let the light '' CHECK ENGINE SOON '' Appear on the desk ??? or it will never appear ???
p.s : if not what i should put the sensor of the stock cat's???
many thanks .
joe
Old 10-03-2007, 03:32 PM
  #103
PainProphet
PainProphet's Avatar
anyone still making these so all I have to do is jack up the car and install them? pm me, zip code: 19968
Old 10-04-2007, 01:31 AM
  #104
malized
malized's Avatar
yes im leaving in lebanon, do u have a answer ??
thx ,
joe
Old 10-04-2007, 07:48 AM
  #105
gothchick
gothchick's Avatar
Answer is by the OP on the first page with pics... Good luck my friend.
Old 10-04-2007, 09:19 PM
  #106
malized
malized's Avatar
Thumbs up
ok thx man ....
i'll double check ...
Old 01-09-2008, 10:24 PM
  #107
dannyboi2088
dannyboi2088's Avatar
sorry i'm a noob.....but i heard that if the CEL comes on then our cars actually slow down in performance because it's run on a different map on the ecu???
also anybody still making these because i would like to order....please pm me detail on where to pay and i'll paypal
Old 01-10-2008, 08:21 AM
  #108
ISMSOLUTIONS
ISMSOLUTIONS's Avatar
This is easy folks - go to Autozone, Napa, wherever and buy a set of spark plug non-foulers...there are DIY's all over the place for this fix.
Rick
Old 01-10-2008, 01:38 PM
  #109
dannyboi2088
i'm so lazy to make one i guess i'll just make one, but other then that does the CEL limit our performance on the car??? like make it slower?
Old 01-11-2008, 05:43 AM
  #110
ISMSOLUTIONS
Getting the cell means the car senses and out of range condition, and it will adjust a/f ratios a bit to compensate. You wil likely not see much of any performance issue, but you will over short time kill your O2 sensors - so at about $170 each - don't be so lazy!!!
Old 01-12-2008, 05:09 AM
  #111
cbr900son
cbr900son's Avatar
I can make and sell u a pir for 20$
Old 01-15-2008, 07:38 PM
  #112
robertsowka
robertsowka's Avatar
if you throw a CEL is it bad for your car or will it hurt performance? if not then cant you just leave it on? i would assume that if it came it your ecu would kinda be on "safe mode" i guess... probably not, just wondering
Old 01-16-2008, 07:15 PM
  #113
malized
malized's Avatar
nice question !
Old 01-17-2008, 07:46 AM
  #114
DustinZ33
DustinZ33's Avatar
read post 110
Old 01-17-2008, 11:37 AM
  #115
malized
malized's Avatar
Originally Posted by Blurr350z
Since installing my Labree test pipes, I threw an SES after about 50 miles. I didn't do the non-fouler trick at first because I thought there was a chance I wouldn't see the light (I have an '04, turns out it must be an '04.5 since I threw the SES). Went down to Pep Boys, spent 8 bucks on the two sets of non-foulers, spent about 15 minutes installing them. There were two sets you could buy, I think the Z takes the 18mm (the guy at the parts desk actually went and got a 350Z O2 sensor to see which size was correct).
Here are the pics of everything. Even though there are alot of threads about this already, I made one because none seem to have pics, and hopefully this thread will clear up any questions for future instals.
First off, for those who don't know, you need to buy TWO pairs of the non-foulers. One pair needs to be drilled out with a 1/2" drill bit (Most drills can't hold this bit, look at the pics of the drill I used... its over 30 years old). Once one set is drilled out, you take a drilled non-fouler and screw it onto the O2 sensor. Then take the NON-drilled one and screw it onto the DRILLED one. So the order goes, O2 sensor-->Drilled-->Non-drilled-->test pipe/cat. Once you go to do the drilling and everything, the order makes sense.
i already make the same trick, but the SES is still ON ...
so what is the next step ???
Old 01-17-2008, 11:56 AM
  #116
DustinZ33
DustinZ33's Avatar
You have to get the ses cleared out. If it happens again, you will need to insert some type of material in between the two nonfoulers to muffle the smell some more. I need to do this as well. I just don't know what material to use. I'm still searching.
Old 01-17-2008, 12:05 PM
  #117
malized
malized's Avatar
ok gr8 pls keep us in touch
thx
Old 03-24-2008, 10:07 AM
  #118
DLH
DLH's Avatar
I've been selling non-foulers for $30 shipped. If I can get a few more orders I'll make the price $25 shipped. 15000 miles with mine and no SES light. If anyone wants a set, PM me or email me. salanci@udel.edu
Email Sent!
Old 04-14-2008, 06:17 PM
  #119
Sc882tt
Sc882tt's Avatar
good job man ..
Old 04-22-2008, 01:38 PM
  #120
mestisoZ
mestisoZ's Avatar
Dude Awesome!!! The Way My Friend Explained It... I Fukin Drilled Both Non Foulers!!! Probably Why Im Gettin A Fukin Check Engine Light! Im Gonng To Do This **** Right Now! Thanks
Quick Reply: Test Pipe SES Non-Fouler Fix... pics
