Homemade Catch Can
#101
on
Originally Posted by gothchick
I'd put a dab of epoxy on it from the inside to seal it up.
#106
on
Head gasket leak perhaps? Mine has never looked milky...
#110
on
I just finished doing mine. I got it all rigged up then realized I had the wrong Husky catch. Mine had a little "tap" looking nozzle on the bottom instead of the nipple and it was leaking air under vacuum. I ended up just getting some clear silicon and filling the valve up to stop it off. I'm letting it dry now and it should work.
Here's a pic of how I installed it.
#111
Got Track!!!!!
on
Nicley done!
I rape my car so hard I need a two catch cans or she starts to bleed out the BOV , but only at the track, not on the street.
My husky on the left and the greddy on the right. I believe Alberto had to do the same.
#112
on
Originally Posted by eagletanggreen
Nicley done!
Thanks, yours looks awesome!
Why did you do the greddy on the right side?
#113
on
so people have been talking about putting a breather on the driver side....any pics?
also, there was another post where the guy put the black foam from a fish tank filter in the catch can instead of steel wool?
and, has anyone found a better way to mount the catch can? i really don't like the zip tie look, but i like the cheap functional idea.
#114
Got Track!!!!!
on
The crank case pressure was so high I needed to alleviate it by installing the second catch can. Oil was coming out the BOV and spilling every where. This mod fixed everything, no damage just alot of cleaning around the engine bay, as you can see it all cleaned up.
Luie
#115
Got Track!!!!!
on
Yeahj look at mine /\
#118
on
I'm going to be installing one of these on the drivers side next weekend. I think I can squeeze it down and out of sight. I forget the size of the turbonetics hose normally used for crank ventilation. I think it may be 1/2"...
#120
ima shirimasen
on
I bought this kit, got it ready to go, only to find out it doesn't quite work with the HR. For one, the other intake is in the way, and there are a few more tubes as well. So I wasn't sure which to hook it up to. Has anyone tried to attach a catch can on the HR?
-Joe
-Joe
