Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Engine, Drivetrain & Forced-Induction (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 12-18-2006, 12:54 PM   #1
EM-EFER
EM-EFER's Avatar
Points: 4,217, Level: 41
Points: 4,217, Level: 41 Points: 4,217, Level: 41 Points: 4,217, Level: 41
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Send a message via AIM to EM-EFER Send a message via Yahoo to EM-EFER
Exclamation DIY- How to install CAMS
*****NOT COMPLETED YET*****
Will be completed by January 5th 07
POSTPONED TO JANUARY 30th
PLEASE DON'T COMMENT UNTIL I AM FINISHED WRITING THIS UP.
This is a long process and on a difficulty of 1-10. This is a 8. Don't attempt without quite a bit of experience. I will generalize a lot of the steps since if you are attempting on your own you should already know where they are and what they do.
I will be adding pictures, diagrams, steps and examples as I go along. This will take me about a week to complete.
In my steps we are not pulling the motor. Although I do recommend pulling the motor!
Total time to complete-
No power tools*14-16 Hours
Power tools*12-14 Hours
MOST IMPORTANT Tools needed-
3/8 Ft/lb torque wrench
3/8 in.lb torque wrench (Be sure it can do a minimum of ** In.LB's)
3/8 Ratchet
3/8 Extended handle ratchet (Huskey makes a great one)
Deep wall 10MM,12MM,14MM,17MM
Every extension size imaginable in 3/8
Products/Parts needed-
2 Tubes High Temp Grey RTV
I RECOMMEND REPLACING THE FOLOWING
16 Cam Cradle bolts (Short) Nissan Part # **********
8 Cam Cradle bolts (Long) Nissan Part # **********
1 Upper Plenum Gasket Nissan Part # ********** (Might need 2 if you have a plenum spacer)
2 Plastic clips for Radiator assembly Nissan Part # **********
1 Large piece of cardboard to protect radiator
1 Tube of assembly lube
1 Roll of Duct tape
Directions-
1. Pull off salt shield
2. Drain oil
3. Drain Anitfreeze. (The plug is on the driver side.) (PHILLIPS)
Remove large coolant hose (TOP) from Radiator to coolant pipe. PASSENGER SIDE
Remove large coolant hose (BOTTOM) from Radiator to lower motor. DRIVER SIDE
Remove all brackets for wiring harness all the way around from side to side back to front.
Take the entire wiring harness and place it towards the rear of motor
Remove Upper plenum
Remove Lower plenum
Cover intake manifold with duct tape
Remove both valve covers in order shown below
**PICTURE
Remove coolant overflow tank
4. Remove radiator fan assembly (I cut off the plastic clips that held the wires to it and bought new ones.)
Place cardboard against radiator to protect it and duck tape it.
Loosen both belt tensioners for AC side and Altenator side. (12MM)
6. Pull off both belts
7. Remove Altenator & Bracket assembly.
8. Remove Power Steering pump and braket.
9. Remove idler pulleys/Brackets.
Remove oil pan as shown in diagram below
**PICTURE
Remove two front upper oil pan bolts (Long Extension)
**PICTURE
Remove all 10MM bolts as shown below. Remove 17MM BOLT located in the center <--Don't miss this one or you will be trying to pry the front timing cover for a year.
**PICTURE
The hardest part of the cam install is removing the front timing cover. Double check you have removed all the bolts. I bought a special nissan tool to remove the timing cover, but broke three of them in the process. I recommend taking 2 small fine tipped phillips screw drivers and inserting them in the notched holes and gently tap them between the front and rear timing cover. After it begins to seperate put another fine tipped screwdriver between the two notches and try to seperate the middle. Work from top to bottom seperating the sealant.
REFRENCE
FRONT TIMING COVER WITH PULLEYS
OIL PAN REMOVED
TIMING COVER OPEN
CAM GEAR RIGHT BANK
CAM GEAR LEFT BANK
LOWER PLENUM
ALTENATOR TIMING COVER
LOWER OIL PAN
Lower Plenum
Intake Manifold
__________________
DNF Materbater
EM-EFER is offline   Reply With Quote
Old 01-17-2007, 08:07 PM   #2
Dirty Dave
Dirty Dave's Avatar
Points: 3,698, Level: 38
Points: 3,698, Level: 38 Points: 3,698, Level: 38 Points: 3,698, Level: 38
Send a message via AIM to Dirty Dave
This will be very interesting to see, are you gonna have everything off to the point where you can take the heads off ? I have been holding back from changing head gaskets to HKS because people are saying you need to remove the motor to get the timing cover off and heads off.
__________________
03' Silverstone 350z, Greddy TT, SGP Long Block, AAM Return Line.
Dirty Dave is offline   Reply With Quote
Old 01-24-2007, 11:47 AM   #3
EM-EFER
EM-EFER's Avatar
Quote:
These are pictures from over summer when I built my motor You don't need to remove the motor to get the heads off or the timing cover. I have did both inside the car without many issues besides space.
__________________
DNF Materbater
Old 01-25-2007, 03:43 PM   #4
Audible Mayhem
My350z
Send a message via AIM to Audible Mayhem Send a message via MSN to Audible Mayhem
dude, please pull the front radiator brace and bumper off, it will help you out soooo much and you are making my back hurt...
it takes about 15 minutes and you wont have to lean all the way over, not sure if you have finished all this, the thread is old...
Audible Mayhem is offline   Reply With Quote
Old 01-25-2007, 03:53 PM   #5
EM-EFER
EM-EFER's Avatar
I already did this over summer Now Iam just giving a walk through.. I will add that in there to.. I didnt do it but Iam sure it would help all the old men on this board.
__________________
DNF Materbater
Old 02-01-2007, 09:37 PM   #6
dave3529
Points: 2,410, Level: 29
Points: 2,410, Level: 29 Points: 2,410, Level: 29 Points: 2,410, Level: 29
i know it differs from car to car and the average gain is supposed to be about 10 to 13 whp but, what kind of gains are likely with intake, and exhaust? and what if i got it tuned? does tuning with the camshafts bring much more out?
__________________
2005 DB 350Z/ HOTCHKIS SWAYS/ TANABEE GF210
dave3529 is offline   Reply With Quote
Old 01-08-2008, 01:05 PM   #7
EM-EFER
EM-EFER's Avatar
Guys... its alot of work
Cut me some slack..
Give me another year
__________________
DNF Materbater
Old 10-13-2008, 08:32 AM   #8
BiGGD198
BiGGD198's Avatar
Send a message via AIM to BiGGD198
haha i think ima have to finish this DIY thread when i do mine....LoL. if anyone can give me some feedback on taking cams out...i will gladly post pictures of my experience and finish this thread.
Dan
__________________
|2k3 SB Nissan 350Z 6MT | Injen Intake | Kinetix SSV | Invidia Test Pipes (Non-Resonated) | HKS Dual Hi-Power Exhaust | Competition Clutch Stage 4 | Competition Clutch Flywheel | LC-1 | LMA-3 | UpRev Tune. COMING SOON : Zex 100 Shot
BiGGD198 is offline   Reply With Quote
Old 04-29-2010, 08:41 AM   #9
Chris@FsP
Vendor - Former Vendor
We should re-title this thread "DIY- How to remove front timing cover"
Chris@FsP is offline   Reply With Quote
Old 05-03-2010, 10:20 AM   #10
SexyRob
Points: 1,606, Level: 23
Points: 1,606, Level: 23 Points: 1,606, Level: 23 Points: 1,606, Level: 23
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
lol... yeah I'm getting some cams in and will be doing it myself. updates/tips would be nice... past the removing the timing cover part.
reading the service manual they want me to set the engine to TDC for the first piston. Can I just put the new cams in the same position as the old ones and go on with my life? or must I reset it?
__________________
2006 G LR Coupe - Still in love
SexyRob is offline   Reply With Quote
Old 05-03-2010, 11:08 AM   #11
Chris@FsP
Might as well do it as the FSM says and set it to TDC. It's not like it's hard to do
My350Z
350 Z
Paid Advertisement
Tags
350z, 360, cam, cams, forum, holder, install, installed, installing, license, nismo, phillips, plate, skyline, xbox
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tomei Camshaft for VQ35HR?? JDMHolic VQ35HR 57 11-19-2009 07:58 AM
Rev Limiter..... zoham55 Engine & Drivetrain 15 05-27-2004 02:31 PM
Jwt Cams ... The Review ... 350trackz Engine & Drivetrain 29 02-10-2004 07:23 PM
censorship thread. ares My350Z.com Forum-related Feedback, Suggestions & Questions 28 08-28-2003 04:42 PM
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
