DIY: Spark Plugs Change (HUGE Pics)
Old 06-29-2008, 08:56 PM
3hree5ive0ero
Retired Admin
3hree5ive0ero's Avatar
Originally Posted by kalil47
Every how many miles do I need to change spark plugs? I got 27k miles on my Z and never changed them. My car has a rough iddle and when I turn on the ac the revs go up a lil and get rougher, kinda unstable rev in neutral. WHAT CAN THE PROBLEM BE?
I think for stock plugs, you can leave them alone until 100k miles. If you've added some sort of FI to your car, it should be done more often.
Old 07-14-2008, 12:05 PM
mestisoZ
mestisoZ's Avatar
hey guys i just installed my new spark plugs i used ngk PLFR5A - 11 plugs. and i didnt move the plenum or intake duct. i just got to the coil packs from the side. anyways when i start the car now i get a rough idle. almost like the cars camming? the plugs are pre gapped? but ima be checking them again to make sure. anyone have any advice on this problem thanks?
Old 07-15-2008, 11:57 AM
McLovin350Z
McLovin350Z's Avatar
Default reply on plugs
i made a mistake when installing the plugs on the intake side i didnt plug the harness together right with the right coil pack.
On the intake side the last two harnesses for the coil pack i had switched.
Make sure that the middle harness goes to the coil pack in the rear and the last last extention goes to the middle
It sounds weird but it is so, that the wires dont get bunched up.....(Nissan made it look clean)
Old 07-16-2008, 10:24 AM
mestisoZ
mestisoZ's Avatar
haha yep thats what it was i figured it out yesterday. doh.. hehe thanks anyways man
Old 07-25-2008, 08:32 AM
tally350z
tally350z's Avatar
Now what kind of plugs are good. I've heard alot about NGK Iridium. I went to autozone and they had 2 kinds, the NGK iridium or autolite double platinum. How are the autolite plugs? does anyone know?
Old 07-25-2008, 12:52 PM
gothchick
gothchick's Avatar
Just get copper: NKG LFR5A-11. They don't last as long, but they do conduct a better spark. And they're less expensive.
Old 07-25-2008, 01:09 PM
3hree5ive0ero
Retired Admin
NGK.
Depending on your set up, a colder spark plug may be better. Again depending on your set up, a hotter or the regular (recommended) may be better.
If you're N/A and will drive in all normal conditions, the recommended spark plug is your best bet. NGK seems to be the popular brand and their prices are good. Copper ones do conduct a better spark, but iridium and platinums are also good and will last you a lot longer than copper ones.
Old 09-13-2008, 12:58 PM
2004Black350z
Exhaust Whore
2004Black350z's Avatar
NGK.
i thought jeremy tibbs said copper was better for the juice
Old 09-13-2008, 01:12 PM
blasian
blasian's Avatar
Yeah, that's what he told me as well.
Old 09-13-2008, 03:03 PM
3hree5ive0ero
Retired Admin
Copper is better. I was just saying that Iridiums will last longer. I have copper plugs in mine.
Old 09-13-2008, 03:07 PM
blasian
blasian's Avatar
Ah, I only read the last post lol. I agree.
Old 09-13-2008, 08:13 PM
3hree5ive0ero
Retired Admin
Come on, guys. My Z's bottle-fed. Do you really think I wouldn't know that little fact? You give me too little credit.
Old 09-14-2008, 01:17 PM
scmtkings4
scmtkings4's Avatar
ok i have a question, generally on spark plugs
just yesterday, i was in my car and i turned the key and the car didnt turn on. you can hear it turning, but it never ignited. Is the spark plug the only possible reason for this? Or might something else be the cause of this? If the spark plug is the only possible reason, then im gonna change mine. Thanks alot
Old 10-24-2008, 05:16 PM
nismo-kidz33
nismo-kidz33's Avatar
anybody tried using the pulstar plasma plugs on their z yet?
Old 02-03-2009, 09:29 AM
chromesilverz
chromesilverz's Avatar
The dealer said the stock plugs were good for 100k miles.
So does the coil assembly have to be replaced at certain intervals?
Old 04-11-2009, 06:57 PM
0jiggy0
0jiggy0's Avatar
The coils get replaced when they die. Theres no schedule for them.
Old 05-28-2009, 12:30 PM
johndoesdamage
johndoesdamage's Avatar
I wanted to know if anyone has used the e3 sparkplugs? or opinion on them, brother told me to get them because he saw on horsepower tv that it helps car. I have my car with bolts on and I just want ngk iridiums.
Old 05-28-2009, 12:51 PM
  #38
tylerxfire
tylerxfire's Avatar
ngk iridium is a much better plug, ive never had a problem with them..buddy of mine just put the e3 plugs in his turbo pt cruiser and burned one up within a few months, melted it i guess from what i heard
Old 06-08-2009, 12:44 PM
  #39
iamshadow
iamshadow's Avatar
anyone every figure out the idle thing? the idle is def different now, feels like a misfire but i have no cel yet, so idk. help?
Old 06-08-2009, 01:03 PM
  #40
tylerxfire
tylerxfire's Avatar
no idea what idle thing u are talking about here..but sounds like u did your own plugs and didnt clip all the clips back together right or mixed them up or just didnt do it correctly, pull and do again correct
Quick Reply: DIY: Spark Plugs Change (HUGE Pics)
