DIY Replacing your belts. Very Easy
The applied pushing force is 22lbs. So, put 22lbs of pressure and then measure. I used the handle of my hammer to press down and put weight (20lbs + hammer weight + little bit of me holding it all = ~22lbs) on top of the hammer to apply the said force. I got somebody else to measure while I held the weight. It's ghetto, but it works.
Thanks a lot
Chris
Retired Admin
Originally Posted by NA&CH
Sounds good. Thats what I will do. I puched down on the belts and then measured to what I tought felt like 22lbs hahaha
Thanks a lot
Chris
Thanks a lot
Chris
Originally Posted by DucondimemayOP
I am not sure if it's a good idea to have news paper between the jack stand and the frame of the car...very dangerous.
on
Well I finally decided to try this... was easy. Thanks for the guide it helped.
I just drove up onto ramps which was enough clearance for me.
I don't have a torque wrench so I have no idea how tight I made the pully's but hopefully its enough and not too much. Whats the worse that can happen, it snaps and then boom there goes my AC and/or power steering and generator. Hopefully will be fine...
Thanks for the guide again...
Thanks a lot I don't think you should be breaking bolts loose with a torque wrench though. Use a breaker bar or a ratchet with a pipe extension for the handle.
Originally Posted by 300zx1985
How do you know when the belts need change? If there is no cracking/fraying/etc on the belt im guessing they are fine?
#38
on
Belt tension/deflector gauge
Anyone have a source for the Kent-Moore belt tension/deflector gauge (kent-Moore Tool " BT3373-F indicated in the Nissan 350Z Service Manual)?
#40
Retired Admin
Originally Posted by WTX350Z
Nope, I use the ol faithful thumb-o-meter.
See my above posts to see how I remedied that.
