DIY Replacing your belts. Very Easy
Old 08-05-2010, 09:44 AM
  #101
stein
stein's Avatar
Originally Posted by chromesilverz
A handheld fish scale and ruler might work if you have one laying around for the tension/deflection.
Perfect!
Old 09-29-2010, 01:51 PM
  #102
sluggoZ
sluggoZ's Avatar
I appreciate this great write-up! THANKS!
Old 10-14-2010, 10:20 AM
  #103
RICHARDHAUNTER
RICHARDHAUNTER's Avatar
Perfec DIY, but how can I measure the tension i´m aplying to the belts?
Old 10-26-2010, 05:50 PM
  #104
Armed Ferret
Armed Ferret's Avatar
exactly how much of this thread did you actually read? the very answer to that question starts on the first page.
Old 11-11-2010, 01:18 PM
  #105
Encino_Man
Encino_Man's Avatar
Do you have to loosen the idler pulleys? Mine are retarded tight. Stripped a half inch craftsmen and I'm calling it a night for now.
Old 11-28-2010, 04:31 PM
  #106
whitetrack
whitetrack's Avatar
Check this out to determine belt wear for non neoprene belts. Neoprene belts would have cracks and missing chunks.
http://www.gatesprograms.com/beltwear
Also for cheap belt tension gauge
http://www.rockauto.com/catalog/rafr...4-91132-197212
Old 02-04-2011, 01:48 AM
  #107
Mcutali
Mcutali's Avatar
why do u need to loosen every pullies nut? why not just the tensioners?
Old 03-03-2011, 10:09 AM
  #108
Zchan03
Zchan03's Avatar
^^^maybe you should try it.... But I don't think from what I remember, that you can just loosen the tensioners without first loosening the pulley nuts you wouldn't be able to move the pulley up or down. The pulley nuts hold the position of the pulley in place once you have them set with the tensioners.
Old 03-05-2011, 10:05 AM
  #109
SirSpeedyZ
SirSpeedyZ's Avatar
Just did this today, get writeup. The only thing I would add is to get it correctly tightened back I counted how many turns I loosened each pulley.
For those interested:
Loosed both pulleys by about a quarter turn.
Lowered AC pulley by about 8 turns.
Lowered Alt Pulley about 10 turns.
Hope that helps someone.
Old 03-14-2011, 01:56 PM
  #110
Blueknight007
Blueknight007's Avatar
Nice write up, thanks for doing it, I was planning on doing this soon; I noticed mine had cracks in it while I was doing the oil change, suckiest part is dealing with the cover underneath, I'll get the parts this weekend oh and I get to finally fix those POS hatch struts, no more cuncussions for me!!woo hoo
Old 03-16-2011, 07:10 AM
  #111
Encino_Man
Encino_Man's Avatar
Anyone know the specs on the ac-idler-pulley bolt? I need a new bolt because mine is stripped.
Old 03-16-2011, 10:29 AM
  #112
sluggoZ
sluggoZ's Avatar
Did you try calling the Nissan dealer Parts Dept.?
They should know......I would call several dealers, they all have different pricing.
Old 03-26-2011, 09:29 AM
  #113
chaparro78
chaparro78's Avatar
Took me a bit longer than I would have liked, a little over 2 hours. Had to remove the down pipe for the supercharger and the engine cover to get to the belts. Figured since all that was off, might as well recharge the air filter as well. But overall was a good write up. Everything came out good to go.
Old 04-01-2011, 07:35 PM
  #114
whipitgood
whipitgood's Avatar
that was a hell of a lot easier than i thought
Old 04-22-2011, 11:17 AM
  #115
Bigalow
Bigalow's Avatar
This may help, also.
Where do you get these manuals?
Old 05-09-2011, 06:24 AM
  #116
bluebadge
bluebadge's Avatar
Thanks for a great comprehensive tutorial!
I wasn't able to gauge the tension, I had to guestimate it, no squeeks or squeels after I was done, anyone knows what happens if you apply more than the recommended amount of tension on the belt? (Apart from the obvious, which would be the belt snapping, which didn't happen) just curious...
Old 05-19-2011, 10:04 AM
  #117
BeastZ
BeastZ's Avatar
I thought I would try to save some people the trouble that I had. From October 2006 to November 2006 Nissan produced the VQ35DE that had a different pulley arrangement and belt routing than the other DE's.
Attached is the FSM figure with the pulley that my Z is missing crossed out.
The typical belt length for a DE is 1175mm, but since I am missing a pulley the belt I need is shorter. (Not sure what the correct measurement should be, waiting on to get the belt in.)
I discovered this problem after sheering off the adjuster bolt, driving around for a week with a squealing (i.e. embarrassing) belt, and way to much time spent on a simple project.
Hope this helps someone.
File Type: bmp
Old 07-31-2011, 02:10 PM
  #118
Snowhiteboiler
Snowhiteboiler's Avatar
dothemath, thanks for putting this and the pics on here. I knocked it out today when I had the shroud off for an oil change. The hardest part was getting the nuts loose on the idler pulleys. After that it was smooth sailing.
Old 09-04-2011, 01:56 AM
  #119
Nismomonkey
Nismomonkey's Avatar
subbing
Old 10-15-2011, 12:47 PM
  #120
stein
stein's Avatar
Supper easy DIY! took less than an hour.
Quick Reply: DIY Replacing your belts. Very Easy
