HOW TO: Install a Walbro GSS342
Old 12-20-2011, 09:28 AM
  #121
phunk
CJ Motorsports
phunk's Avatar
http://blog.cj-motorsports.com/2011/...tallation.aspx
Old 08-24-2012, 10:07 AM
  #122
ADMAN
ADMAN's Avatar
My OEM pump finally died. Hoping to do this install this weekend. Thanks for the link.
Old 05-08-2013, 08:18 PM
  #123
Bpb713
Newbie
Bpb713's Avatar
Originally Posted by phunk
if you do the modifications to the regulator and swirl jet as outlined in the how-to, then you will have stock fuel pressure with a walbro installed
okay so i just installed my walbro following all instructions listed in the how to. okay so i drilled out my swirl jet.(before running across your post) so does this mean i just defeated the whole purpose of installing a walbro!?!? i just installed rc440s and a vortech v3 on 10-11 psi. so i assume ill need to try to locate another swirl jet? i will mention that yesterday i drove the car with the 440s in on stock fuel pump and when i would throttle it hard its like the car would choke up for a spit second as if it was starved for fuel. now after installing the walbro it acts fine.
Old 05-27-2013, 08:18 PM
  #124
Bpb713
Newbie
Bpb713's Avatar
Car is running an idling fine now, had an intake leak cause I install kinetix velocity at the same time.. But my question is, since I drilled out the swirl jet did I just defeat the whole purpose of installing the walbro? I also drilled the regulator since I'm not running a return fuel system
Old 09-20-2013, 04:28 AM
  #125
Rick*K
Rick*K's Avatar
Do the same mods need to be done to the sending unit if using a Deatschwerks pump?
Old 11-04-2013, 04:52 PM
  #126
beezbo
beezbo's Avatar
Help! I drilled the swirl jet out barely and I mean barely out too far causing a small leak. Am I ok to repair the pin hole leak? How pressurized is this part?
Old 02-12-2014, 04:51 PM
  #127
LoKatzer
LoKatzer's Avatar
This was a huge help. Thanks phunk!
Old 06-22-2014, 04:19 PM
  #128
crd00
crd00's Avatar
I'm going to use a 5/64 bit which is .078 on the swirl jet. Has anyone done this and it worked fine on their pump?
Old 06-24-2014, 12:15 PM
  #129
crd00
crd00's Avatar
Anyone think this will be okay?
Old 07-16-2014, 08:26 AM
  #130
Squirrel240sx
Squirrel240sx's Avatar
The link to the writeup is returning a 404 error. Does anyone happen to still have that write-up? I've searched all over and the results all point to either that site, or to threads linking to that site. It seems as though no one else thought to archive the instructions anywhere either (derp).
Old 07-17-2014, 09:38 AM
  #131
black_gst
black_gst's Avatar
I 2nd that request im trying to install a 255 and need this, if anyone saved it as a pdf or anything please PM
Thanks
Adam
Old 07-28-2014, 04:59 AM
  #132
cturnbull802
cturnbull802's Avatar
bump anyone have this guide saved?
think i found it -
http://tech.cj-motorsports.com/?p=25
Old 06-16-2015, 01:34 PM
  #133
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Does anyone have a pdf copy or a (working) link for the walbro 255 pump install/mod?
I need to trouble shoot a few weird noises...
Old 06-18-2015, 07:18 AM
  #134
cturnbull802
i made a copy of it on my page.
http://www.christurnbull.com/?page_id=116
jksstar (02-01-2016)
Old 06-18-2015, 05:51 PM
  #135
bealljk
bealljk's Avatar
^ Thank you, thank you and thank you - I actually did this last night based of CJ's tech write up without pictures...wasnt too terribly difficult but pictures sure help!
Old 06-30-2015, 03:53 PM
  #136
phunk2
phunk2's Avatar
FULLY REVISED WITH UPDATED PHOTOS AND TEXT
DOWNLOADABLE PDF!!
http://host.cj-motorsports.com/pdf/3...uel%20Pump.pdf
Old 06-30-2015, 06:07 PM
  #137
bealljk
bealljk's Avatar
^thank you!
phunk2 (06-15-2016)
Old 06-14-2016, 10:07 PM
  #138
Smoove
Smoove's Avatar
DOWNLOADABLE PDF!!
Great doc.
Thanks
phunk2 (06-15-2016)
07-10-2022 07:44 AM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
Quick Reply: HOW TO: Install a Walbro GSS342
