Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Engine, Drivetrain & Forced-Induction (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 04-19-2008, 09:53 PM   #1
frankie945
frankie945's Avatar
Default Water/Methanol Injection install 350z
Snow performance Boost Cooler Stage II #20010
I threw out the hardware that came with the kit. Used self tapping screws.
Nylon tubing way to short. Bought longer tubing.
Used a different led light.
Black box is hidden in the battery Bay.
Excuse all the extra wires hanging in the floor board.
Hope these pic's help on any ideas.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
__________________
Sold the Z bought a JK. But I miss all the drama in the FI forum..
frankie945 is offline   Reply With Quote
Old 04-19-2008, 09:57 PM   #2
carfi179
carfi179's Avatar
Points: 2,929, Level: 33
Points: 2,929, Level: 33 Points: 2,929, Level: 33 Points: 2,929, Level: 33
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Any before and after dyno comparison? what water/meth mix your using?
__________________
TEAM HYBRID --- Corvette C6 Z06/ Chrysler 07' 300C SRT8
carfi179 is offline   Reply With Quote
Old 04-19-2008, 10:08 PM   #3
frankie945
frankie945's Avatar
Quote:
I will know Tues morning going to the dyno tuner said a 30 hp gain going with a 50/50 mix. I hear of guys putting windshield wiper fluid in there but it has detergants in it that is not good on your motor. Will post up #'s
__________________
Old 04-20-2008, 06:39 AM   #4
eagletanggreen
Got Track!!!!!
eagletanggreen's Avatar
Points: 4,947, Level: 44
Points: 4,947, Level: 44 Points: 4,947, Level: 44 Points: 4,947, Level: 44
Send a message via AIM to eagletanggreen Send a message via Yahoo to eagletanggreen
Nice install/ write up!
__________________
700WHP JWT 850BB TT ---> Sold
11.1@ 133.7mph
2008 M3 Coupe12.3@ 115 mph
www.luiezendejasracing.com
eagletanggreen is offline   Reply With Quote
Old 04-21-2008, 09:52 AM   #5
Z_boy912
Points: 3,418, Level: 36
Points: 3,418, Level: 36 Points: 3,418, Level: 36 Points: 3,418, Level: 36
Nice install. good job man..
I have few questions though;
1. what is the black box?
2. I assume the unit on the floor matt is the snow performance controller, no?
3. does the Reservoir tank have to be higher than the pump? reason?
4. the LED light indicates when you have a low level right? why did you change it?
5. I see that you are running 2 lines, 1 is white and the other is green, what are they?
6. are you using the nozzles that came with the kit? what size are they?
7. where did you get the kit from and for how much?
Z_boy912 is offline   Reply With Quote
Old 04-21-2008, 12:28 PM   #6
str8dum1
Points: 3,968, Level: 40
Points: 3,968, Level: 40 Points: 3,968, Level: 40 Points: 3,968, Level: 40
Today's Activity: 33.1%
Today's Activity: 33.1% Today's Activity: 33.1% Today's Activity: 33.1%
1. the controller
2. thats the UTEC Tuna
3. shurflo pumps dont create alot of suction, they run best gravity fed
4. led is usually wired to show when the pump is on, there is no low level indicator in his pics. thats another 20$ option
5. i would bet the green line is the stock rear window pisser line
__________________
VQ38DETT with SFR Twin 6262 on ProEFI128 Corn Fed
str8dum1 is offline   Reply With Quote
Old 04-21-2008, 01:02 PM   #7
frankie945
frankie945's Avatar
Quote:
Originally Posted by str8dum1
1. the controller
+ 1 Thank you. light is to know that the pump is on. You would be real lazy to buy a low level sensor. The led they give you is really small.
__________________
Old 04-21-2008, 02:12 PM   #8
turismo
turismo's Avatar
Send a message via AIM to turismo
Nice writeup
turismo is offline   Reply With Quote
Old 04-27-2008, 09:59 PM   #9
Ep3
nice i also have a procharger and i am relocating the maf to move the nozzle further from the TB i thought it had to be 6-9 inches away the vari-cool kit i have recomends right after the ICany numbers on this?
__________________
QUOTE from Cannysage "it's not all that worth it, but it doesn't matter.. you'll end up getting it anyways, soon or later, just to feed your addiction"
Ep3 is offline   Reply With Quote
Old 04-28-2008, 09:09 AM   #10
frankie945
frankie945's Avatar
Quote:
it does not mater how close to the tb as long as the nozzle is spraying in a funnel pattern 360 degrees spray.It is not like NOS. I gained 21 whp and 12 wtq safely. with this set up highly recommend.
__________________
Old 05-20-2008, 06:42 AM   #11
Blwn_By_Twins
Blwn_By_Twins's Avatar
Points: 2,442, Level: 29
Points: 2,442, Level: 29 Points: 2,442, Level: 29 Points: 2,442, Level: 29
I have another question. Why did you remove your spare then replace it with a 25lbs weight?
Nice job though!
__________________
It's so close I can almost feel it.
Blwn_By_Twins is offline   Reply With Quote
Old 05-20-2008, 07:06 AM   #12
MI 35th
OGPremierMafia
MI 35th's Avatar
Points: 5,427, Level: 47
Points: 5,427, Level: 47 Points: 5,427, Level: 47 Points: 5,427, Level: 47
Today's Activity: 7.2%
Today's Activity: 7.2% Today's Activity: 7.2% Today's Activity: 7.2%
Send a message via AIM to MI 35th
Meth users, windhield washer fluid sucks, it will yield the same results 90% but it has detergents and those dont break down as well in the heat.
Either use Distilled water with M1 Meth or just Distilled H20 to reduce knock.
__________________
Boosted Performance Single Turbo
MI 35th is offline   Reply With Quote
Old 05-20-2008, 09:03 AM   #13
frankie945
frankie945's Avatar
Quote:
Nice job though!
Need traction = more weight. and couldn't keep spare the pump is in the way, who needs it anyway.
__________________
Old 05-20-2008, 09:06 AM   #14
frankie945
frankie945's Avatar
you are exactly right buy straight meth and distilled water. do not use windshield washer fluid.
__________________
Old 05-20-2008, 09:14 AM   #15
MI 35th
OGPremierMafia
MI 35th's Avatar
I am doing a meth kit with my utec as a controller, boost or rpm dependent solenoid.
__________________
Old 05-20-2008, 09:18 AM   #16
frankie945
frankie945's Avatar
The black box works great I start spraying at 2 psi. And it's real easy to setup you just dial in the boost which u want to start spraying and how much. There is only 2 adjustments.
__________________
Old 06-04-2008, 09:30 PM   #17
mikez97
mikez97's Avatar
Send a message via AIM to mikez97
where did you purchase the meth injection kit?
__________________
2k7 Carbon Silver 6MT495whp@10.5lbs
VQ35HR HKS TT DD - P.F.
mikez97 is offline   Reply With Quote
Old 06-12-2008, 01:40 PM   #18
Bumble_Zee
FREEDOM FIGHTER
Bumble_Zee's Avatar
Send a message via Yahoo to Bumble_Zee
Quote:
nice write up man, but the 25lbs weight got me laughing... our Z weigh like 2500lbs right?(EDIT: 3200LBS) LOL
it would be nice to get a bigger container huh? I guess we don't have any other space to put the meth/alc kit around the engine bay? hmmm... this will be my upgrade along with a procharger...
__________________
Si Vis Pacem, Para Bellum...
Bumble_Zee is offline   Reply With Quote
Old 06-12-2008, 02:04 PM   #19
Crom
Valhalla
Crom's Avatar
Points: 5,410, Level: 47
Points: 5,410, Level: 47 Points: 5,410, Level: 47 Points: 5,410, Level: 47
Today's Activity: 0.8%
Today's Activity: 0.8% Today's Activity: 0.8% Today's Activity: 0.8%
Cool..nice work.
__________________
<< TRACK HEADLIGHT COVERS >>
Thanks to teh Sponsors : Corner3 Garage, RHD Japan, APP, Goliath Construction
Crom is offline   Reply With Quote
Old 07-23-2008, 02:45 PM   #20
frankie945
frankie945's Avatar
Snow performance has just upgraded there nozzles to all steel so you wont have to worry about the nozzle blowing apart. If you have a plastic one and won't a steel nozzle just send Snow performance a email and they will take care of you for free. Just a little update....
__________________
My350Z
350 Z
Paid Advertisement
Tags
2005, 350z, fluid, injection, install, kit, meth, methanol, mod, spray, washer, water, watermeth, watermethanol, windshield, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
