Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Engine, Drivetrain & Forced-Induction (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 01-03-2009, 08:46 AM   #1
filmmakerZ
filmmakerZ's Avatar
Points: 1,361, Level: 20
Points: 1,361, Level: 20 Points: 1,361, Level: 20 Points: 1,361, Level: 20
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Send a message via Yahoo to filmmakerZ
Post DIY - Nismo Cold Air Intake Installation
While there are several posts for installing a CAI, I failed to find a COMPREHENSIVE one for Nismo. So, as I did for my brakes and rotors, I figured I would do the work myself and hopefully live to write about it. Well, here I am, two days after the install and still alive. This post is a ‘How To’ for installing the Nismo R-Tune Cold Air Intake.
Getting Started
Recommended Tools:
1 - Car jack (the one that comes with the car works fine)
1 - Standard socket ratchet set with a 10mm metric and 5/16” standard socket
1 – Standard 5/16” open-end/boxed-end wrench
1 – Standard needle nose pliers
1 - Common (flathead) screwdriver
1 – Gigantic tub of patience
Preparation
  1. Make sure the car has been sitting for at least three hours (or however long to ensure the engine is 100% temperature cool).
  2. Make sure the car is on a flat surface.
  3. Set the parking brake.
  4. Remove the left front tire.
  5. Place a towel or fender protector on the left fender to protect the paint, as you will be leaning inside the engine bay from this area.
Removing the stock Air Intake (Old & Busted)
  1. Loosen the hose clamp at the throttle body.
  2. Remove the bolt securing the inlet pipe to the intake manifold.
  3. With the needle nose pliers, GENTLY Loosen the lower hose clamp.
  4. Lift the inlet pipe and release the breather hose. Remove the inlet pipe.
  5. Release the MAF sensor wiring harness from the air box.
  6. GENTLY unplug the MAF sensor.
  7. Remove the bolt that secures the air box.
  8. Remove the plastic rivet that secures the air horn. BE EXTRA CAREFUL TO NOT BREAK THE PLASTIC RIVETS.
  9. Slide the air horn forward and remove the air box from the engine bay.
  10. Remove the four bolts that secure the MAF sensor housing.
  11. Remove the air conditioning bracket bolt that sits in between the two rubber plugs on the frame rail.
  12. Release the wiring harness from the frame rail by GENTLY popping out the plastic rivets.
  13. GENTLY remove the rivet that secures the wires to the bracket that secured the original air box.
  14. On the side of the frame rail, GENTLY slide the blue connector up. DO NOT DISCONNECT.
  15. GENTLY remove the rivets inside the left front fender liner.
  16. Remove the four bolts underneath the left front fender liner.
Installing the Cold Air Intake system (New Hotness)
Recommended Tools:
1 – gigantic cup of patience
NOTE: THE STEPS FOR THIS INSTALLATION BEGIN AFTER STEP 16 FOR REMOVING THE STOCK AIR INTAKE.
  1. Install the rubber mount on the air conditioning bracket.
    1. Place the MAF senor wiring harness from step 5 on the rubber mount.
    2. Place the aluminum spacer supplied with your Nismo parts on the wiring harness and screw the rubber mount onto the frame rail.
  2. Secure the blue connector removed in step 14 to the rubber mount with the wiring harness.
  3. Connect the MAF sensor housing to the supplied adapter using the Nismo washers and bolts.
  4. Install the upper inlet pipe (the one with ‘Nismo’ on it) to the throttle body.
    1. Connect the breather hose to the bottom of the inlet pipe.
    2. Place a hose adapter on the throttle body and slide the inlet pipe in the other end of the adapter. Use the size 52 clamp on the throttle body and use a size 48 clamp on the inlet pipe.
  5. Using a hose adapter, secure the MAF sensor housing to the upper inlet pipe (MAF sensor pointing down) with two size 48 clamps.
  6. Assemble the center pipe.
    1. Place the Air Bypass Valve (the foam cone) on the long end of the pipe.
    2. Use a size 48 clamp to secure one end of a hose adapter to the short end of the pipe.
  7. Connect the center pipe hose adapter to the MAF sensor housing and face the Air Bypass Valve down into the left wheelbase area.
  8. Connect the lower pipe to the Air Bypass Valve.
    1. Slide the bracket of the lower pipe onto the rubber mount and secure it with the supplied fender washer and nut. **This step takes A LOT of patience, so take your time**
    2. Secure the air filter to the other end of the lower pipe. Make sure that the filter is not pressed against anything or is obstructed.
  9. Reinstall the left front fender liner with the rivets that you were so careful not to destroy when you removed them.
  10. Reinstall the air horn and secure it with its rivet.
  11. Tighten all clamps and make sure that all pipes are secure (DO NOT OVERTIGHTEN).
  12. Say a prayer of thanks.
The Nismo CAI System is installed
In Conclusion
I hope the steps are explained clearly and are easy to follow. For all you that are visual, I have included some pictures of my installation.
Pic 1 - Nismo CAI Parts
Pic 2 - Left front fender liner removed
Pic 3 - New Inlet Pipe and MAF Sensor Housing installed
Pic 4 - New Inlet Pipe, MAF Sensor Housing, and Center Pipe installed
Pic 5 - Stock AI removed
__________________
Stillen|Nismo|Tanabe|Motordyne|Okenbono|JL Audio|Kenwood|Focal
filmmakerZ is offline   Reply With Quote
Old 09-04-2009, 07:00 AM   #2
Nismospeed4life
Nismospeed4life's Avatar
Points: 3,070, Level: 34
Points: 3,070, Level: 34 Points: 3,070, Level: 34 Points: 3,070, Level: 34
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Very Nice write-up! Thanks!!!
Nismospeed4life is offline   Reply With Quote
Old 09-07-2009, 06:51 PM   #3
filmmakerZ
filmmakerZ's Avatar
Thanks.
__________________
Old 09-18-2009, 04:03 PM   #4
ck2003Z
Well written, very helpful post. Thanks!!
ck2003Z is offline   Reply With Quote
Old 09-18-2009, 05:27 PM   #5
Nismospeed4life
Do you have any pictures of it installed in your car...
Old 09-21-2009, 05:01 AM   #6
filmmakerZ
filmmakerZ's Avatar
The third and fourth photos are pictures of the installation in my car. I didn't think to take any of the filter itself before I put the wheel well back together, so what you see on this page is all that I have.
I will be sure to show more when I do the dual intake installation on the 370 Nismo (drool).
__________________
Old 10-27-2009, 10:47 PM   #7
FOOZ350Z
I am purchasing a nismo cold air intake but I find 2 different model numbers for the intake rzn35 and rzn36 is this a issue because the rzn36 I found for a cheaper price from leemotor in Maine. Anyone know of a better place to purchase from??
FOOZ350Z is offline   Reply With Quote
Old 10-27-2009, 10:48 PM   #8
FOOZ350Z
Default Nismo intake
Old 10-27-2009, 10:51 PM   #9
Nismospeed4life
Quote:
http://www.thenismoshop.com/ikorb.ph...ategory_id=188
Old 12-14-2009, 05:55 PM   #10
mikeross
Nice write up! Been very helpful..
mikeross is offline   Reply With Quote
Old 12-15-2009, 12:31 PM   #11
IN350Z
really nice thx for write up , helped.
IN350Z is offline   Reply With Quote
Old 02-10-2010, 07:27 PM   #12
mikeross
I was having a problem with my CAI filter. Anybody knows where I could find the best deal for it? I want to replace it and I want a shop to buy from probably near LA. Thanks!
Old 03-03-2010, 05:58 AM   #13
snowboarder599
snowboarder599's Avatar
Points: 801, Level: 15
Points: 801, Level: 15 Points: 801, Level: 15 Points: 801, Level: 15
Send a message via AIM to snowboarder599
Quote:
Originally Posted by mikeross View Post
I was having a problem with my cold air intake filter. Anybody knows where I could find the best deal for it? I want to replace it and I want a shop to buy from probably near LA. Thanks!
Check out ebay... They have a lot of really good deals, but make sure that you don't get duped into buying some of the really cheap stuff. I made that mistake early on, and got a CAI that didn't have installtion instructions, or even a heat shield! But other that that, ebay is a pretty good place to get a lot of your aftermarket upgrades!
__________________
AEM:Jet:BLOX:Heliex:Pioneer:Billet:HKS:Stillen:Grounded:B&M: Mishimoto:Cobb:JWT
snowboarder599 is offline   Reply With Quote
Old 04-08-2010, 01:10 PM   #14
sluggoZ
sluggoZ's Avatar
Points: 4,129, Level: 40
Points: 4,129, Level: 40 Points: 4,129, Level: 40 Points: 4,129, Level: 40
Today's Activity: 7.5%
Today's Activity: 7.5% Today's Activity: 7.5% Today's Activity: 7.5%
Excelllent write-up!
Is it necessary to un-plug the battery before starting the job?
__________________
My '04.5 SB ZR still feels like HEAVEN...what a cooool ride doing the twisties!
sluggoZ is offline   Reply With Quote
Old 04-08-2010, 01:25 PM   #15
AcidJake75
Moderator
TX, Tech, DIY, OT, & Marketplace
AcidJake75's Avatar
jacob.perez1 Jake_Perez
Points: 3,788, Level: 38
Points: 3,788, Level: 38 Points: 3,788, Level: 38 Points: 3,788, Level: 38
Today's Activity: 17.4%
Today's Activity: 17.4% Today's Activity: 17.4% Today's Activity: 17.4%
Send a message via AIM to AcidJake75 Send a message via MSN to AcidJake75 Send a message via Yahoo to AcidJake75
^^^ yes - especially if your unplugging sensors..
__________________
05 D-Blue: UPREV, JWT, Carbonetic LSD, 3.9 Gears, GReddy, Stance, Megan, MB, Enkei, MotorDyne, Stillen, SPL, SPC, Crawford, NRG..
*ICE* Alpine, Boston & Custom harness bar/hood/hatch struts&solid diff bushings by Jason Z-YA
AcidJake75 is offline   Reply With Quote
Old 05-04-2010, 05:11 PM   #16
vervius
not bad... gave me a plan of action at least... good install plan!
vervius is offline   Reply With Quote
Old 05-10-2010, 05:19 AM   #17
filmmakerZ
filmmakerZ's Avatar
I'm glad it helped.
__________________
Old 05-18-2010, 09:36 AM   #18
69 fingers
69 fingers's Avatar
Points: 1,588, Level: 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
So I have a NISMO CAI installed on my car, but one of the pieces is broken. Im not sure what the name of it is, but its the foam covered knuckle joint piece. I think some told me once it was a snorkle of sorts? Anyway it has splite in half and is being held together by zip ties. Does anyone know if its possible to buy just that part?
__________________
That's what she said.
69 fingers is offline   Reply With Quote
Old 05-18-2010, 09:43 AM   #19
snowboarder599
Quote:
http://www.importpartspro.com/betepoalztu01.html
Is that what you are looking for?
__________________
Old 08-12-2010, 08:06 PM   #20
BigEquity
It is a water bypass valve. Mine broke as well. I asked the dealer if they could order just that part. No luck! I was looking at one of these...
http://www.amazon.com/AEM-20-403S-Ai.../dp/B000CFQF5W
I may just pop the cone filter on the end of the tube where the MAF is located until i can find the correct part.
BigEquity is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
350z, air, cai, cold, diy, fender, forums, horn, intake, maf, make, nismo, ram, remove, replace, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
