Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Engine, Drivetrain & Forced-Induction (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 01-19-2009, 08:03 AM   #1
JBGKing
JBGKing's Avatar
Points: 1,107, Level: 18
Points: 1,107, Level: 18 Points: 1,107, Level: 18 Points: 1,107, Level: 18
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default DIY - 2007 350Z GrillCraft MX Install
This my first post so I hope I do JUSTICE!!!
I was starting this thread for 4 point jacking but I ran out of time and decided to install the GrilleCraft MX series lower grille. The grill instruction process instructions can be found at http://www.grillcraft.com/installs/i...id=167&print=1
My 2007 350Z Touring Redline with my Jacking Tools which include the Blitz8000 Rhino Ramps, 4 -6 ton Stands,
3 Ton Jack, and two wheel chocks.
JBGKing is offline   Reply With Quote
Old 01-19-2009, 10:04 AM   #2
JBGKing
JBGKing's Avatar
Default #2
Here are some pictures of the Jacking Equipment I used. I also made jack protectors out of 2x4 presurre treated wood to use the slots under the jacking points. I lowered the car slowly to make sure the wood wouldn't spilt. Always cut the slots against the grain.
Old 01-19-2009, 10:09 AM   #3
JBGKing
JBGKing's Avatar
Default #3
Basically I spent the whole afternoon on making sure that the jacking procedure went successful and decided to call it a day when the front of the car was jacked up properly.
Old 01-19-2009, 10:14 AM   #4
JBGKing
JBGKing's Avatar
Default #4
I also marked the front outline of the ramps so I would have no problem lowering the car when the job was done.
The Pictures of the 2x4 wood cut to fit my jack-stands held up to the task.
Old 01-19-2009, 10:18 AM   #5
JBGKing
JBGKing's Avatar
Default #5
Back to the grill install. First remove the top center trim by separating the two tabs ans pulling straight out. Then remove the screws behind the grill to remove the outside top trim pieces the same way as the center piece.
Old 01-19-2009, 10:23 AM   #6
JBGKing
JBGKing's Avatar
Default #6
Next remove the lower grill trim. You have to remove the plastic clips holding the plastic baffles behind each side of the grill. These clips are easily removed with a screwdriver. Just pull up on the center of the clip to release them and reinstall in the opposite order.
Old 01-19-2009, 10:25 AM   #7
JBGKing
JBGKing's Avatar
Default #7
A picture of the front with the grill trim removed.
Old 01-19-2009, 10:31 AM   #8
JBGKing
JBGKing's Avatar
Default #8
You have to dill a hole in the baffle to be able to install the mounting screws of the new grill. The instructions don't give you the size of the hole or place to make the hole. I used a 7/8" hole-saw and dilled both baffles at 2-5/8" from the top of the baffle. The position of the hole worked out great but I would suggest dilling an 1-1/8" hole for an easier install.
Old 01-19-2009, 10:41 AM   #9
JBGKing
JBGKing's Avatar
Default #9
Next you have to make the grille holes with a scribe. I suggest scribing the whole hole then dilling the center of the scribe with a 3/16" bit. Although I did this installation myself a second pair of hands would be helpful with this step. The grill comes with "U" nuts and screws to install the new grill but one of the my "U" nuts was missing. It actually worked out because I used a nut and bolt on the top tab. Installing the screws was a challenge. The tool I used after a lot of cursing was a 1/4" short extension with a 10mm socket. You can see it in the middle of all the tools i tried.
Old 01-19-2009, 10:44 AM   #10
JBGKing
JBGKing's Avatar
Thumbs up #10
The end result was great. I have already got compliments on the installation the first time i took the Z out for a cruise.
Old 01-19-2009, 10:46 AM   #11
BlueZ33
BlueZ33's Avatar
Points: 2,275, Level: 28
Points: 2,275, Level: 28 Points: 2,275, Level: 28 Points: 2,275, Level: 28
Send a message via AIM to BlueZ33
wheres the pic of the grill installed????
__________________
2K8 CARBON SILVER 6MT - NISM0 / Berk / Pioneer / JL Audio / Infinity / Stillen / Volk GT-S Phantom Edition
BlueZ33 is offline   Reply With Quote
Old 01-19-2009, 10:49 AM   #12
JBGKing
JBGKing's Avatar
Default Four Point Jacking Up Next with Borla Exhaust
I did mark the jacks with the 2x4 wood supports so I will use the same blocks each time at the same position. I hope this will help anyone who is thinking about installing a new grill.
JG
Old 01-19-2009, 10:50 AM   #13
JBGKing
JBGKing's Avatar
Quote:
Patience is a virtue
Old 01-19-2009, 01:40 PM   #14
TPerry109
TPerry109's Avatar
Points: 1,212, Level: 19
Points: 1,212, Level: 19 Points: 1,212, Level: 19 Points: 1,212, Level: 19
Can I have your OEM grill? I want to get rid of the aftermarket grill that came with the car. PM me if you want it off your hands.
__________________
Tyler -- 04' Silverstone Nismo S-tune Z -- 95' Notchtop SR20DET Powered S14
TPerry109 is offline   Reply With Quote
Old 01-19-2009, 07:14 PM   #15
JBGKing
JBGKing's Avatar
The trim pieces are no good without the frame which is attached to the nose piece. Good Luck!!!
Old 01-19-2009, 08:33 PM   #16
Vas@Extended
Vendor - Former Vendor
Dont wanna sound like an A$$ but... that looks awful..stock grille > that^. Props for doing the work your self though.
Vas@Extended is offline   Reply With Quote
Old 01-19-2009, 08:51 PM   #17
stevezcar
stevezcar's Avatar
Points: 2,642, Level: 31
Points: 2,642, Level: 31 Points: 2,642, Level: 31 Points: 2,642, Level: 31
Today's Activity: 0.6%
Today's Activity: 0.6% Today's Activity: 0.6% Today's Activity: 0.6%
I agree with Vas. That grille doesnt look good. Put your stock one back on. It looks much better. Buy a 300c if you want a chrome grille. Anyways, great job doing the work yourself and the info on the how-to.
__________________
07' Nissan 350z: San Marino Blue, Nismo wheels, Stillen sway bars, AEM cold air intake, Nismo catback exhaust, Veilside carbonfiber front lip, and more to come.
stevezcar is offline   Reply With Quote
Old 01-20-2009, 01:32 AM   #18
Al Kapwned
Al Kapwned's Avatar
Points: 1,894, Level: 25
Points: 1,894, Level: 25 Points: 1,894, Level: 25 Points: 1,894, Level: 25
Today's Activity: 1.4%
Today's Activity: 1.4% Today's Activity: 1.4% Today's Activity: 1.4%
Al Kapwned is offline   Reply With Quote
Old 01-20-2009, 02:44 AM   #19
chopperman
chopperman's Avatar
Points: 5,393, Level: 47
Points: 5,393, Level: 47 Points: 5,393, Level: 47 Points: 5,393, Level: 47
Send a message via AIM to chopperman Send a message via Yahoo to chopperman Send a message via Skype™ to chopperman
You should reverse all those steps. Im not feeling it dude. Grills never looked good on a z
__________________
2003 Lemans Sunset Greddy Twins / Sgp built longblock
chopperman is offline   Reply With Quote
Old 01-20-2009, 02:48 AM   #20
teh215
teh215's Avatar
Points: 5,504, Level: 47
Points: 5,504, Level: 47 Points: 5,504, Level: 47 Points: 5,504, Level: 47
Send a message via AIM to teh215 Send a message via Yahoo to teh215
Not my cup of tea but congrats on the 2 install and posting in the wrong forum.
__________________
Where are we going? ......and why am I in this handbasket?
teh215 is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
2007, 350z, buys, diy, forum, grill, grillcraft, grills, group, install, jack, jacking, points, remove, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
