Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Engine, Drivetrain & Forced-Induction (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 03-23-2009, 01:10 PM   #1
SilverTrack03
Default Changing your Transmission and Rear Diff fluid the easy way!
I Just got done changing my transmission and rear diff fluid, and followed the instructions in the other thread in here. They are great however the suction gun SUCKS to use, it takes forever is messy and overall just a pain. After getting too or three pumps out of the way I started to think of other ways to fill this fluid for the transmission. Now On my Talon AWD, we used a long tube connected to a funnel to fill the trans from the top. So I started to look at that and what do I see, but I direct route from the trans fill hole to the engine bay. So I got up and grabbed my trusty fill from my talon, and snaked it through and it worked great.
Tools you will need:
10mm allen socket
Fluid of your choice I used Redline, MTL, MT-90 and a gear oil with lsd additives from them.
Drain pan
3-4ft of 7/16 hose longer is better always cut down to what you need
A sharpie Cap
Funnel that fits into the 7/16 hose
Few zip ties
Here is the tool I made. You push the funnel in one end. Take your sharpie cap and cut open the close end, being careful not to crack it. Push the smaller end of the sharpie cap into the end of the hose; this creates a perfect fit for the trans fill hole and the rear end fill hole.
Here is the opening you will snake this through to fill the transmission
Here is how it will look once you have the funnel in place with the tube on it
Here is from the bottom looking up with tube running down
And have someone fill from the top, you can do it yourself but I found it easier just in case the tube slips out of the trans or starts to leak a bit which it will slightly but not a lot at all just a few drips. Fill to the level in the car manual just over 3quarts if I remember right. But when full fluid will leak out of the fill hole when you pull out the fill tube, let some drain out and then put back in your fill plug.
Now for the rear end, this one looks like there is no way to fill this using your long tube you made. And I agree I thought I was going to have to use the damn suction gun. But there is a way. The drain tube is on the passenger side of the car and is almost a straight shot to the wheel with nothing in its way. You will run the tube through the spokes of your wheel above the rotor, through the spring to the fill hole. Making sure there is a constant downward slop to the rear diff. Its not a huge slope but there is one, make sure there are no dips or anything and you are set to start filling. Takes just under 2 quarts, I fill both quarts and let the excess drain out.
Here are the pictures so you get the idea. I used zip ties to hold my funnel in place so I didn’t spill anything by mistake. Again you will get a few drops leak out during filling but not a lot. But when you remove the tube there will be lots of fluid draining out if you fill all 2 quarts so have a pan ready.
This is the funnel through the wheel
Under the car looking up, see the tube ran through the spring to keep up straight and sloping down.
Hope you get the idea, it will fit and make a slight downward flow to the diff, The fluid will drain a little slow because of this slight downward grade, but it does work and works well.
And there you have it, easy as cake to change the fluid this way, so much better that the dumb ass suction pump gun bull crap.
Again dont get this dumb thing.
SilverTrack03 is offline   Reply With Quote
Old 03-23-2009, 01:41 PM   #2
Rowlett
Rowlett's Avatar
Points: 2,003, Level: 27
Points: 2,003, Level: 27 Points: 2,003, Level: 27 Points: 2,003, Level: 27
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Sweet, I'll be using your way for the tranny..
__________________
Hello
Rowlett is offline   Reply With Quote
Old 03-23-2009, 03:35 PM   #3
booey1979
booey1979's Avatar
Points: 2,140, Level: 27
Points: 2,140, Level: 27 Points: 2,140, Level: 27 Points: 2,140, Level: 27
Today's Activity: 4.6%
Today's Activity: 4.6% Today's Activity: 4.6% Today's Activity: 4.6%
hmmm why didnt i think of that? I had a transfer pump method (one they use to siphone fuel from the gas tank is used, and its much better than the grease gun method. Otherwise, I'll try this route next time.
booey1979 is offline   Reply With Quote
Old 03-25-2009, 11:43 AM   #4
MikeW
MikeW's Avatar
Points: 3,429, Level: 36
Points: 3,429, Level: 36 Points: 3,429, Level: 36 Points: 3,429, Level: 36
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Thanks for sharing- great method!
MikeW is offline   Reply With Quote
Old 03-25-2009, 12:33 PM   #5
RandomHer0
Points: 3,295, Level: 35
Points: 3,295, Level: 35 Points: 3,295, Level: 35 Points: 3,295, Level: 35
Today's Activity: 11.0%
Today's Activity: 11.0% Today's Activity: 11.0% Today's Activity: 11.0%
I dunno I bought this and its pretty simple. One end goes in your fluid, the other in the tranny/diff...pump away...
RandomHer0 is offline   Reply With Quote
Old 03-25-2009, 12:58 PM   #6
SilverTrack03
Yea the pump gun like you posted would be easy. I didnt see one so i got the suction gun and it sucked so i made this and its easy and fast. So im sharing
Old 03-26-2009, 08:18 AM   #7
RandomHer0
Yeah I agree, the gun sucks, good job.
Old 03-30-2009, 08:37 PM   #8
Escobar
Escobar's Avatar
Points: 3,440, Level: 36
Points: 3,440, Level: 36 Points: 3,440, Level: 36 Points: 3,440, Level: 36
Thanks, Im about to do this fluid change, this is gonna help.
Escobar is offline   Reply With Quote
Old 05-22-2009, 02:14 AM   #9
roygrady
Thanks, I'll save this info for when I need to do a change (not too far away)
roygrady is offline   Reply With Quote
Old 05-22-2009, 05:45 PM   #10
driver350
Points: 951, Level: 16
Points: 951, Level: 16 Points: 951, Level: 16 Points: 951, Level: 16
Today's Activity: 0.6%
Today's Activity: 0.6% Today's Activity: 0.6% Today's Activity: 0.6%
Sweet, I have some extra beer funnels lying around.... I'll have to mod them first
driver350 is offline   Reply With Quote
Old 05-27-2009, 09:55 PM   #11
Driver06
Driver06's Avatar
Points: 2,129, Level: 27
Points: 2,129, Level: 27 Points: 2,129, Level: 27 Points: 2,129, Level: 27
Quote:
Nothern tools has them
__________________
APSTT over 30k boosted stock block.. Still on Julians tune
Driver06 is offline   Reply With Quote
Old 06-08-2009, 04:20 PM   #12
Sleepy79
Sleepy79's Avatar
Points: 2,561, Level: 30
Points: 2,561, Level: 30 Points: 2,561, Level: 30 Points: 2,561, Level: 30
Amsoil sells a pump that works with their bottles. Looks like a pump from a liquid soap dispenser and comes with the clear vinyl tubing.
__________________
#206 35th
Sleepy79 is offline   Reply With Quote
Old 06-17-2009, 03:47 PM   #13
rockinbboy
rockinbboy's Avatar
Points: 4,456, Level: 42
Points: 4,456, Level: 42 Points: 4,456, Level: 42 Points: 4,456, Level: 42
Today's Activity: 1.1%
Today's Activity: 1.1% Today's Activity: 1.1% Today's Activity: 1.1%
How do you guys prevent overfilling? Unless you guys fill exactly X quarts for the diff/trans
__________________
2006 Daytona Blue Enthusiast 6 speed: Bone Stock as of 02/16/2006 K&N Drop In as of 06/6/2008 Eagle F1 All Seasons as of 06/21/2008
rockinbboy is offline   Reply With Quote
Old 06-17-2009, 03:59 PM   #14
marques1
marques1's Avatar
Points: 5,490, Level: 47
Points: 5,490, Level: 47 Points: 5,490, Level: 47 Points: 5,490, Level: 47
Today's Activity: 3.2%
Today's Activity: 3.2% Today's Activity: 3.2% Today's Activity: 3.2%
Thanks for the diy
marques1 is offline   Reply With Quote
Old 06-17-2009, 06:43 PM   #15
06Enthusiast
Quote:
Once you reach full capacity, the excess will begin to run out of the fill hole. It's pretty much impossible to overfill. I always try to get a little too much in, then let the excess drain off. Once the draining stops I put the plug back in.
__________________
MREV2, 5/16" spacer, Berk HFC's, Stillen Y-pipe, Apex-i WS2 exhaust, Redline fluids
06Enthusiast is offline   Reply With Quote
Old 06-18-2009, 08:55 AM   #16
rockinbboy
rockinbboy's Avatar
Quote:
Well, I can somewhat understand that if you opened the fill hole, the excess will drain out but that sounds like a mess.
In the examples above with the funnel - rubber tube, lets say someone starts filling it up, then you know you went too much once the fuild comes up to the funnel as it backs-up. Until then, you don't know if you overfilled. That is really where my question pertains.
__________________
Old 06-18-2009, 09:38 AM   #17
rcdash
rcdash's Avatar
Points: 4,722, Level: 43
Points: 4,722, Level: 43 Points: 4,722, Level: 43 Points: 4,722, Level: 43
Today's Activity: 5.4%
Today's Activity: 5.4% Today's Activity: 5.4% Today's Activity: 5.4%
You have to have a drain pan underneath. So it doesn't matter how much you put in because the excess will come out. You know ahead of time, roughly how much you need to add for a complete fill.
I have the red pump pictured above and it sucks as well. Sometimes it will just stop and you have to play with the hoses, check for leaks, etc while oil goes everywhere. Yuck.
I'm trying this way next time too. D@mn carbonetic diff forces me to change fluid every 3k (they actually recommend every 1800 miles!).
__________________
build thread
rcdash is offline   Reply With Quote
Old 06-18-2009, 05:55 PM   #18
Eddie K.
Points: 1,198, Level: 18
Points: 1,198, Level: 18 Points: 1,198, Level: 18 Points: 1,198, Level: 18
Thanks for the info I just bought my oil for this and I was thinking about buying that pump. I will try this way it looks simple. I love this fourm,
it will answer your questions.
Eddie K. is offline   Reply With Quote
Old 07-06-2009, 01:54 PM   #19
SilverTrack03
I got a PM about the size of the sharpie needed so i thought i would metion it. Its just your normal size sharpie cap. And as for how it fits int he trans/diff it fits snug, not really tight and not really loose, perfect for holding the line inplace and allowing the fluid to pass through into the trans/diff.
Old 04-07-2010, 10:28 PM   #20
King350Z
King350Z's Avatar
Points: 1,485, Level: 21
Points: 1,485, Level: 21 Points: 1,485, Level: 21 Points: 1,485, Level: 21
For anyone who hasn't tried to do this on their own yet, this is a great way to do it. Very easy. Good tips OP
__________________
03 Performance 6MT 289.7whp/266.7wtq Osiris tuned
King350Z is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
350z, change, diff, diy, fill, fluid, grease, gun, hose, nissan, pull, pump, rear, suction, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
