DIY - Quaife LSD INSTALL - PICS!
Old 04-21-2013, 12:19 AM
  #81
BlaqMagic
BlaqMagic's Avatar
Originally Posted by Voboy
^- Looks you got a swapped 3.7 + VLSD pumpkin.... that QDF10L model isn't going to work. Were the axle stubs out of that thing different lengths? That would also confirm its a VLSD... You'll need a the QDF13L...
Hmm that's what I assumed originally. I didn't check the stub axle lengths. What threw me off was that the 2nd diff I bought taken from a wrecked stock 5AT was a 3.5 with also the same height measurements to what was in my car with the 3.7 (both to spec of a VLSD model). Looks like I'll have to sell it and buy the QDF13L then.
Cheers.
Old 05-27-2013, 01:54 PM
  #82
JackMcNASTY
JackMcNASTY's Avatar
I bought a stock LSD and want to install this in my base open diff. I am pretty sure I have a good handle on everthing exept the side flanges or axle stubs that go into the diff housing.
Are they different between the open diff and the LSD?
Old 06-18-2013, 02:01 PM
  #83
bmyles
bmyles's Avatar
Yes, if you bought a factory VLSD and you have an open diff, you need VLSD axle stubs.
Old 04-16-2014, 01:01 PM
  #84
scsi
scsi's Avatar
Originally Posted by AcidJake75
bearing Product SKU: 38440-Z33001 (Part #)
is this part number a kit for the whole diff or do i need (2) of these, one for each side?
are there any seals that need replacing at the drive shaft and axles?
should i go with OEM ring bolts or just go to home depot for something of the same spec? what grade?
if i mark my original ring, will i still need to worry about adjusting backlash? i still need to read up on what the heck backlash is but it is a big unknown that is making this install sound a bit more complicated
thanks!
Old 05-07-2014, 11:06 PM
  #85
shane310
shane310's Avatar
when you guys did your diff installs did you mark the bearing caps in their correct locations? it says to do that but when I did mine I didn't mark so I just slid the diff back in , seems to turn fine , do you guys think this will be a problem and if so how can I fix it if I never marked them when I pull the diff out , to know where to put them back in.
Old 05-28-2014, 11:53 PM
  #86
Z33KLF
Z33KLF's Avatar
Such a nice thread! Clear and direct! Thanks man!
07-10-2022 07:44 AM
350Z_Al
10-29-2020 07:44 PM
Quick Reply: DIY - Quaife LSD INSTALL - PICS!
