Clicking Noise from Rear Axle,
Old 05-22-2012, 07:45 AM
  #101
F2CMaDMaXX
F2CMaDMaXX's Avatar
Now i've got to check if it's my bearing or the axle making this noise, i have to assume the only real way of checking the bearing is by trying to move the wheel top and bottom?
Old 05-22-2012, 07:52 AM
  #102
jerseystyle
jerseystyle's Avatar
If it was the bearings, you'd think it would make the clicking noise more frequently
Old 05-22-2012, 07:55 AM
  #103
jerseystyle
Originally Posted by beasters
I removed the rear axle nut and all the other nuts and bolts and I have been trying to hit out my driver side rear axle and i cant get it so go in all the way... I've been using a rubber mallet.. any suggestions?
Maybe a peice of wood and a hammer (if you can get a small peice of wood to fit)
Old 05-22-2012, 09:33 AM
  #104
beasters
beasters's Avatar
HELP! I was able to remove my passenger rear axle without too much trouble but I have been pounding the **** out of the driverside with a rubber mallet and i even tried a hammer and 2x4 and still cant get it out.. can someone please give me some suggestions here. Should i try to spray some pb blaster in there or something?
Old 05-22-2012, 10:02 AM
  #105
saywat?
saywat?'s Avatar
i thought bad wheel bearing made the thumping sound while driving
Old 05-22-2012, 11:01 AM
  #106
Italianjoe1
Italianjoe1's Avatar
What do you mean by all the way? It won't go fully out of the hub until you have the rest of the axle hanging free and past all the exhaust parts and rear suspension. Just get it loose, then pull the whole axle out from the bottom.
Originally Posted by saywat?
wat happens if u dont repair this? is it jus a noise issue? does it damage anything?
Just noise, it's only heard because there is nothing to damp the metal-to-metal contact noise from the normal lash. The play is still there after you lube it, but you don't hear it hitting anymore.
Old 05-22-2012, 11:04 AM
  #107
saywat?
saywat?'s Avatar
^i see thanks. sounds too much of a hassle for me to fix if its not damaging anything. im used to it clicking lol
Old 05-22-2012, 11:06 AM
  #108
Italianjoe1
Pretty much. But if you are only getting this click, it's not because of the wheel bearing. If it's making other strange noises then you need to troubleshoot it properly.
It won't move at all? If you can't free it up at all, I'd suggest as you said use some sort of penetrating oil (PB Blaster is awesome), let it sit for a bit and work it's way in. After that, try hitting it as solidly as possible. Put the axle nut back on the axle backwards, turn it in until the flange is just over the end of the axle. Put a piece of aluminum or brass or something across it, and strike it sharply with a hammer.
Sometimes the rubber mallet or piece of wood just doesn't give the sharp hit needed to break it loose. It should only take one hit, don't sit and beat on it.
Don't know about a thumping, it's usually a growling type noise or can be a humming if it's more mild.
Old 05-22-2012, 11:08 AM
  #109
Italianjoe1
It's a very quick fix honestly, once I found this thread I did it on my car and i'm so happy I don't have to hear it anymore. I actually pulled the whole axle so I could clean the rust off and lube it all up properly, but doing it as they mention here with just pushing it in and adding grease, could be done in 15 min.
Old 05-22-2012, 11:10 AM
  #110
saywat?
saywat?'s Avatar
oh yea humming sounds more right.
Old 05-22-2012, 05:32 PM
  #111
F2CMaDMaXX
F2CMaDMaXX's Avatar
Yeah, mine has a slight humm/whirr at about 55-60.
Old 05-23-2012, 02:08 PM
  #112
beasters
beasters's Avatar
I used some pb blaster and used a thin piece of metal against the axle and gave it a coupe good even hits with a hammer and she finally broke loose! I finished everything up last night and NO MORE CLICKING! thanks again for the advice man.
Old 05-23-2012, 03:37 PM
  #113
Italianjoe1
Glad you got it!
If you're crazy like me about stuff like that, it will irritate the crap outta you. I know it's nothing, but by the same logic I don't want to hear it if it can be prevented.
Old 05-23-2012, 03:41 PM
  #114
Italianjoe1
If it's only prevalent at one speed, it may be tire related. Wheel bearing nosie tends to just build with speed, and if your car is quiet you can hear it start from a lower speed and get louder, although if it's not really that bad yet you may not hear it over the wind as the speed climbs.
Doesn't help that Z's are a bit loud anyway.
Old 05-23-2012, 04:53 PM
  #115
saywat?
saywat?'s Avatar
^yea could be flat spots in the tire would do that
Old 05-23-2012, 05:01 PM
  #116
F2CMaDMaXX
F2CMaDMaXX's Avatar
I thought it was tyres too, but then this possibility turned up, guess i have to go get the jack out and check.
Not sure how it is when i'm going slower, the roads here are very noisy anyway, and as you said, the 350 road noise doesn't help.
It would be nice if it was just the axle grease fix.
Old 05-27-2012, 08:09 AM
  #117
rafiG
rafiG's Avatar
any hints for getting stuck axle nut off...
i have electric impact and 3/4 breaker bar with huge axle socket set but cant break it free. will be looking for a small torch...
any other hints or ideas so i dont mess up the threads or the axle itself.
thanks
Old 05-27-2012, 08:10 AM
  #118
rafiG
rafiG's Avatar
thats what im dealing with... its almost surely bad bearing.
Old 05-27-2012, 11:20 AM
  #119
OldManZ350
OldManZ350's Avatar
thanks
Put a 2-3 foot extension on your breaker bar, use a piece of tubing.
I used the 3 foot handle from my floor jack, makes it easy.
Also, spray penitrating oil on the nut and let it sit for 10 min.
Old 05-27-2012, 11:44 AM
  #120
jerseystyle
^^^^This.
Quick Reply: Clicking Noise from Rear Axle,
