the clutch slave bleed nipple looks just like that of the brakes.......
edit:
pics of what it looks like:
Just use a typical vinyl hose and bleed into a dos XX bottle!
-J
you say it's the same as brakes, does that means that i can call a budy to pump 2-3 times and open the bleeder screw and let the liquid fall and repeat the process all over without buying anything??
Missed this thread when it was originally posted, but I want to mention that fuel hose is not a good choice for brake fluid. It will slowly dissolve and contaminate the fluid. You want to use EPDM hose to eliminate that concern.
