DIY: Replace Valve Cover Gaskets
#62
From what I can see (which is why I posted a pic) that particular set from that company comes with a grommet set. So if R&Ds instructions called for drilling a hole in the baffle to fit a larger grommet, I will probably do more searching and pick up that B/A kit and see if the grommets fit. All I know is there is no way in F#@$@ hell I am paying 500 bucks because a 2 dollar part failed....
#63
Well I fail at life. Lol so I'm changing my vcg today, and I saw how different the stock spark plug gaskets are. They differ by about 1 mm from the one I got for the "vq35de". So I put the old seal back and sealedit with vrt gray. Looks awesome but lets see if it will hold, that was leaking anyway so I don't think it couldbe wworse. I will be getting a used valve cover and swap it out if this leaks. I also saw my valve civer breather tube was broken, so I'm going to replace mine, maybe AutoZone has hoses.
#65
It wasn't that much trouble TougeZ, I needed to change the cover gaskets anyhow, so it only took maybe 20 more minutes to open the hole and remove/ inspect the leaking seal. The seal I bought matched 80% but it was about 1 mm short on outside lip diameter so it did not fit exactly. So I took the old seal and sealed it in the valv cover with rvt. The worse that could happen is the seal leaks, which just means I have to do the work again, which to me isn't that big of a deal. I made a video of my work and I will be making a thread tomorrow for it. I am sure it will help someone. Also now that I took the measurements of my seal I can go ahead and find an exact one, becauseif R&D can sell them from nissan, I can find em.
#68
GUYS! The thread is up! the video is rather long so it might take a while for youtube to process it! hopefully they wont block it for some background music LOL
https://my350z.com/forum/maintenance...r-gaskets.html
#73
It's not really that bad, after I opened up the hole using the hole saw, I generously applied the rtv to the inner \/ part of the seal and the inside of the seal seat on the valve cover. I pressed it in place then added some more rtv on the outside. Then I left it out to air dry for 24 hours. If properly cleaned and degreased, there is no reason for it to leak. Plus it beats swapping covers.
#78
on
ok so I did my valve cover gaskets today and my sparkplugs because I didn't know when the last time they where changed. While doing this I did pull off both cam actuators. Car ran perfect before doing this
Im now pulling codes
p0300 Random Multiple Cylinder Misfire
P0011 cam position actuator a-bunk 1 timing over-adv
P0021 cam position actuator a-bunk 2 timing over-adv
Any Thoughts?
Any Thoughts?
#79
on
Any Thoughts?
Any Thoughts?
#80
Ironic. I just did my other valve cover gakset bank 2. I used some tinyRtv under and over on the actual gasket bc I was getting a leak. Mine are L-FB rebuilt covers w brand new gaskets. Didnt read entire thread but I would def add a little rvt or gasket stuff to be safe as you're in there unless you wanna dig back into it like I did.
