| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into My350Z.com, click logo to login |
| Register | 370/350Z Photo Gallery | FAQ | Members List | Calendar | Arcade | Search | Today's Posts | Mark Forums Read | Garage | TSB & Recalls | Used Cars | Vendor Directory |
| Welcome to my350z.com! |
Welcome to my350z.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
Thread Tools | Search this Thread |
#1 |
I'm going to start off with saying this "kit" is not for someone who has never worked on cars ..
I AM NOT responsible if you mess up your car, tranny, fingers, etc this is just a tool to help someone decide if they want to do this mod themselves or pay someone and if you do decide to do it yourself, this should help make the install go smoothly ![]() ............................................................ ...................................... Tools - 10mm, 14mm, 19mm sockets / 14mm wrench drain pan torque wrenches (ft lb for drain plug .. inch lb for everything else) - I had to buy inch lb torque wrench .. $40 @ napa funnel 5mm allen head socket stiff wire (use to help get shims out valve body) dikes / pliers flat screwdriver punch or 1/4" drive extension (drive in tapered orfice) light hammer Supplies - 8 quarts NISSAN S-MATIC ATF (do not use anything else) $8.12 / quart with discount (work at dodge dealer) .. they wanted $18 two rolls of paper towel or shop towels Transgo Valve Body Upgrade Kit $295 (really fast free shipping from forged performance .. also avail. @ GTM) Vaseline or suitable assembly lube / grease (hold balls in place) Instructions - Download both VB Removal and Transgo Install pdf files off GTM website Start One Day Trial with transgo website and download three more files (Study all and become familiar with the parts, bolts, etc before starting) 1) Jack car up and set on jack stands, then drain tranny fluid (4 quarts), re-install drain plug at 35 ft lb ![]() ![]() 2) Remove two bolts holding the bracket that 02 sensor wires mount to .. one on passenger side with 14mm wrench .. drivers side with socket .. then remove wire clip from bracket for easy install unclip o2 sensor wires and push everything out of the way ![]() ![]() ![]() 3) Take 10mm bolts out of tranny pan and drop, drain, and put to the side (wont need it for a while) there will be another quart or so in the pan then you see this ![]() 4) Get out the instructions .. unhook the wires on the bottom .. then take out and label bolts according to the diagram (A, B, C, ETC) ... I used paper with letters on them to organize the bolts (or you could use bags) get organized b/c there are ALOT of pieces to keep up with ![]() NOTE - Unclip the two things circled in red before unbolting .. clip on side of the VB sucks when your holding the vb up .. haha 5) BE CAREFUL dropping the valve body .. there are wires you have to disconnect on top (around 6" of slack in them) put a glove on or paper towel between your hand and the valve body .. this is where I cut my finger .. the pickup is razor sharp after that little struggle .. you get this ![]() go ahead and take a break b/c that was the "easy part" ..the harder part is next 6) Following the instructions for removing electronics / solenoids .. remove / label bolts and keep solenoids in order ![]() 7) Remove / Label filter bolts .. then remove the manual valve body and watch for the spring and ball inside ![]() ![]() ![]() 8) Remove Temp Sensor and Relief Ball & Spring ![]() Around now you should have something that looks like this ![]() 9) Again follow the instructions to remove the upper to lower vb bolts .. and lower to upper then lift the upper vb off WITH the separator plate so the balls don't fall out of the upper .. flip over as an assembly and set down (no mods to upper) only lower vb and separator plate get worked on also .. take note where the balls are in the lower vb section (yours may differ by VB) ![]() ![]() 10) The fun part begins .. installing the kit .. take out the transgo vb install instructions and follow them for location and color of springs DO ONE AT A TIME and double check everything I used a piece of thick wire with a hook on the end to help push out the shims .. installing springs on left side is easy, right side are stiffer / harder ![]() ![]() ![]() ![]() ![]() ![]() ![]() and your organized mess of parts should look like this now ![]() 11) Measure each drill bit in the kit and / or order them from small to large .. then carefully drill out the seperator plate holes according to the instructions BE VERY CAREFUL AND DOUBLE CHECK THE LOCATIONS BEFORE DRILLING I noticed the holes are shiny that need to be drilled out .. if you locate a hole and it isnt shiny .. dont drill it out and check it again ![]() 12) Make sure the separator plate is clean of metal shavings, check all of the balls in upper and lower VB (I put Vaseline on them to be safe and hold them) .. then Vaseline the filters onto the separator plate carefully flip upper vb / separator plate over onto lower and make sure the filters stay in place and aligned Torque to - 65 to 70 inch pounds then start assembling reversal of the instructions .. make sure to put the bolts in the correct holes ![]() ![]() 13) Re-Install manual valve body, vb filter, temp sensor and relief ball / spring NOTE - Everything torques to 65 to 70 INCH lb ![]() Vaseline the ball to help keep it in place ![]() ![]() 14) Re-Install Electronics board, Soleniods (in order), and wiring ![]() ![]() ![]() 15) Tap the "tapered orfice" into the hole in the transmission before putting the valve body back in .. make sure it is below the surface I used a 1/4" drive extension .. book says punch .. but either works ![]() 16) INSTALL VB I got my brother to help since it is awkward to hold, hook up wires, align and bolt up follow instructions for bolts, but make sure you get this metal stud in the little clip up in the tranny ![]() 17) bolt up the pan .. torque to 95 inch lb (service manual says 7.9 ft lb) .. then bolt the bracket for the o2 sensor wires back up ![]() 18) lower the car down and fill up the transmission (mine took just over 7 quarts) .. start engine, run through each gear P, R, N, D ... after 5 minutes check cold side of dipstick .. once you get it right .. bolt the dipstick down and DONE !!! just hope it works .. take it for a drive .. be easy for a few miles and shifting through all gears a few times (get air out of vb) then let it rip .. just watch out for telephone poles and ditches .. haha it was raining when I finished .. every shift over 4K threw the car sideways and tires spinning If anyone has any questions just shoot me a PM .. EDIT - I reset the computer after the install .. just disconnect the battery cables for a minute or so .. after 100 miles the kit has seemed and I like it alot
__________________
'07 Touring .. 5AT .. Dodge Antenna .. 35% Tint .. Tein S-Tech .. K&N .. Transgo VB Last edited by Adrians07Z; 11-02-2009 at 01:00 PM. |
#2 |
how much was teh kit?? and how much lower did ur car get when u installed teins?? good luck bro.. and great job!!!
#3 |
the transgo kit was $295 w/ free shipping from forged performance
guess I need to add the prices .. real quick gotta go through and check stuff too b/c I just finished the diy the tein s-techs are around .5 to .75 inch drop .. looks good, but not too low to hit stuff
__________________
'07 Touring .. 5AT .. Dodge Antenna .. 35% Tint .. Tein S-Tech .. K&N .. Transgo VB Last edited by Adrians07Z; 10-31-2009 at 06:53 PM. |
#4 |
damn it looks complicated might have to ask you to do mine if I shipped it you ha
#5 | |
Quote:
__________________
'07 Touring .. 5AT .. Dodge Antenna .. 35% Tint .. Tein S-Tech .. K&N .. Transgo VB |
#6 |
Good work!! Congrats on the successful install.
#7 |
is that the same transmission as the 5AT from 2003-2006?
__________________
Stillen/JWT Intake | Z-Tube | UR Crank Pulley | E-Fan | Catch Can | GG 10 Wire | MD 1/2" Spacer | DCE TB Spacer | 350Z Suspension | SPC Camber | Stillen Sways | CS Tie Brace | Stillen Damper | DC Headers | Kinetix HFC | MD XYZ + VQ |
#8 |
yes .. the transgo kit will work on every 5AT 350z (03-08)
the only difference will be slight differences in locations of check balls and some other things .. they are covered in the instructions .. my 07 vb was slightly different with the two check balls in the lower vb sections, and the relief ball location I believe there are 3 different vb's .. 03-04, 05-06, 07-08 all use same kit and instructions (major differences are covered in the instructions)
__________________
'07 Touring .. 5AT .. Dodge Antenna .. 35% Tint .. Tein S-Tech .. K&N .. Transgo VB Last edited by Adrians07Z; 11-01-2009 at 07:55 PM. |
#9 |
i pwnz on halo3
![]() My Garage |
wow, nice this diy. you should do this on the side. had i waited to get my vb upgrade i would be contacting you.
__________________
Greddy TT/ HKS ssqv bov/ Mishimoto radiator/ Z-1 hoses/Stillen vb upgrade/ seibon vt carbon fiber hood/ Berk hfc/Defi blue racer/Innovative wideband/mishimoto fans |
#10 |
I got off work early today .. so made a short video on the way home .. traffic sucked or I would of got a longer one
but for now this should help a little .. this is after 100 miles with the kit .. computer was reset with the kit .. that reminds me I need to add that to the DIY this is turning right onto a highway .. rolled out then got in it .. if you turn the volume up you can hear the tires chirp stock 07 HR w/ good stock rear tires .. only mod would be k&n filters .. but doubt they did anything
__________________
'07 Touring .. 5AT .. Dodge Antenna .. 35% Tint .. Tein S-Tech .. K&N .. Transgo VB Last edited by Adrians07Z; 11-02-2009 at 01:05 PM. |
#11 | |
Quote:
how does it compare to the video? .. I read it was not as strong as the transgo (gtm / forged) kit
__________________
#12 |
Full Member
How long did it take?
__________________
'05 SB ZR |
#13 |
7 hours ..
took my time following each step and organizing all the bolts / parts
__________________
#14 | |
i pwnz on halo3
![]() My Garage |
Quote:
__________________
#15 |
stillens upgrade .. they only do it
the transgo .. you can either buy the kit and do it yourself ($295) or pay Forged Performance or GTM around $800 to install it
__________________
#16 |
though it looks pretty involving, Im pretty sure I could ahve done it myself now that i have seen this. Too late now since I already had a shop do it... Ohhhh well
But this is definitely an excellent upgrade! Man...I really want to take it apart and check my VB though. My 4-5 shift is very sluggish... All the others are lightning quick.
__________________
|| D E R A I L // |
#17 |
.. dont know if the 4-5 shift is changed .. really never get the chance to be on it hard enough to go that fast .. haha I'm lucky to be in it long enough to bark 3rd
__________________
#18 |
u didnt need to remove any electronics, just leave that side of the vb on an old pillow and careful not to ding the solenoids. saves u at least 30 mins of work. heres the installationon my truck, we have the same transmission
from 1st to 2nd it barks the tire (turn upthe volume also on 3rd it hits hard as well but since im too heavy it wont chirp lol
#19 |
yea .. figured I didn't "have" to
but really all it was is a few allen head bolts .. the electronics "board" then the solenoids pull out didn't take long to take the electronics off .. most of the time was spent jacking the car up, installing the kit (springs and drilling holes), then filling it all back up
__________________
| Tags |
| 350z, body, diy, g35, gt, kit, motorsport, nissan, plate, separator, shift, transgo, upgrade, valve, vb, works |
