"HOW TO" VDC Fully Disabled Button
Old 09-02-2012, 03:07 AM
Scrildo
Scrildo's Avatar
Some good info in here wow I'm late lol
Old 03-28-2015, 01:37 PM
cristian92
cristian92's Avatar
#46 for some extra HP
Old 10-27-2017, 07:02 AM
Ivan Trevizo
Ivan Trevizo's Avatar
Can you help me locate the YAW rate g sensor in my 2004 350z? My number is 5053395126
Old 01-03-2018, 02:34 PM
Franknbeans
Franknbeans's Avatar
I've read most every post on this topic. I wonder, wouldn't it be a lot easier if I just put a switch on the VDC pulling the ground wire? If I have the option, I always put a switch inline with the ground wire instead of the hot wire. There's less of a chance for something to get fried.
Old 02-03-2018, 05:21 PM
fastfast
fastfast's Avatar
Originally Posted by surfo
Yes thanks!, but on that write up you CUT the wire! and I don´t like cutting oem wires. So I decided to add a separated harness and make this fully reversible with no damage at all to oem parts.
I´m working on getting a new OEM VDC button, so this VDC Full Off mod has a OEM switch, and since just cuting for a fraction of a second the G sensor signal will keep VDC Fully dissabled until you turn off and on the cars ignition, there is no need for a fully on/off switch, just a push button. and there is no better push button than a oem one that can be fitter just next to the VDC stock one. And I will design a decal or something like DANGER or RACE MODE for it
Hey surfo did you ever end up swapping switches for a OEM VDC switch? Been trying to figure out how to wire up an OEM switch for this and know little about how they work. There are 4 pins on the switch (see photo). I figured 1 and 2 were power in/out, but when connected and pressed an "ABS" light flashes on the dash and nothing changes (nothing happens after powering the car off then back on). Can anyone help me make sense of the diagram? Thanks
Attached Thumbnails "HOW TO" VDC Fully Disabled Button-screen-shot-2018-01-31-at-9.55.31-pm.png
Old 02-03-2018, 05:29 PM
Franknbeans
So I jumped on ebay and bought a seat heater switch in loo of the VDC switch. I couldn't find a VDC switch with the plug also.
(switch came from a G35)
I grabbed my wire tester and started poking at the wires to see what ones are connected when the switch is on / off.
The future plan.
1. paint the switch. Color, unsure... red?
2. Insert the switch in the middle of the seat heater switches. There's a blank there, I hope it fits proper.
3. Cut the GROUND wire to the YAW/VDC module that's in the center console and connect it to the switch via the Yellow and Black wires. So with the switch on the UP position, the ground would be working as normal. When the switch is off (Middle) or on the low heat seating the ground will be pulled, thus disabling the VDC fully.
I know this doesn't help you out with your switch, but I figured this would be a back up plan for you.
Old 03-21-2018, 03:05 PM
06platinumG
06platinumG's Avatar
OK, I'm about to do this and have a though and would like some feed back. I'm going to splice into the power line for the Yaw sensor and connect an on/off switch. I was thinking I would use the factory VDC switch on the dash. Disconnect the factory wires from the switch and slice them together, then connect the wires from the yaw sensor to the switch. This would then mean VDC is on or fully off and I would lose the partial off function that comes from the factory.
Does anyone see and issue with bypassing the factory function?
Old 03-21-2018, 03:13 PM
Franknbeans
I didn't mess with the power wire. You can achieve the same effect by using the ground wire and not chance blowing a fuse or the yaw sensor. I ended up using the seat heater switch because I wasn't sure if the VDC switch had two wires that were a constant ON. I did end up buying a 350z seat heater switch because I didn't like the Full VDC (blue) switch not matching the others. To me, this is the simplest way to do it.
Old 03-21-2018, 04:45 PM
06platinumG
Well I can add a new switch but thought just using the factory VDC would be the cleanest look. I haven't p pulled the plug yet to see if it's just two wires. I don't care if I have the factory partial off option if I have full off.
Yea, the ground wire would be best. Need to figure out which wire that is.
Old 03-21-2018, 06:02 PM
06platinumG
Well the factory VDC switch has four wires so I will need to find a wiring diagram to figure out what they all are
Old 03-22-2018, 05:45 AM
Franknbeans
What i ended up doing was getting a electronic multi-reader and touching pins until I found two that where connected.
If you plan on removing the stock VDC, you need to do some research in the wiring to see if you need to cut and splice wires together once the switch is unplugged. (Does unplugging the switch light up any lights on the dash?)
Old 03-25-2018, 11:52 AM
06platinumG
Well I got it done but ended up using a separate switch since I couldn't determine what the wires connected to the factory switch were.
Also I found out that disabling the yaw sensor you also loose RAS as that light along with the slip and VDC light are on now.
Old 03-25-2018, 02:42 PM
Franknbeans
RAS? The only light I have on when the switch is flipped is the Slip and VDC
Old 03-25-2018, 02:46 PM
06platinumG
Well if you don't have RAS (Rear Active Steer) you wouldn't get the light
Old 03-25-2018, 02:47 PM
Franknbeans
YEah, no clue what that was nor the 350 had rear steering.
Old 03-25-2018, 02:50 PM
06platinumG
Don't if it was an option on the Z but it was on the G and then only a few cars were ordered with it.
Old 03-25-2018, 07:23 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
HICAS was never an option on Z33, thankfully. Z32 and Infiniti only.
Old 03-25-2018, 08:10 PM
  #38
06platinumG
Why do you say "thankfully"?
Old 08-28-2018, 10:14 AM
  #39
KRK.Z33
KRK.Z33's Avatar
Should an 03 Enthusiast have a yaw/g rate sensor? I apologize in advance if there is a thread on this elsewhere or if I missed something on here.
I just swapped out my VLSD for a welded and had planned on wiring up a switch to have the option to disable VDC/TCS/ABS etc
I removed my center console to see that there was no sensor.. will TCS off disable everything besides ABS?
Old 09-10-2018, 03:56 PM
  #40
Desert Z
Desert Z's Avatar
Yours does not have VDC lucky bastard.
Quick Reply: "HOW TO" VDC Fully Disabled Button
