5AT to 6MT Swap INFO, ***, DIY, GUIDE Thread!
#63
Neutral Position Switch
The neutral position switch is what controls cruise control. You will not need to wire this in if you have disabled cruise control or are running an aftermarket steering wheel setup.
You will need to wire Pin 102 on the ECU(Green/Orange Stripe) to either spade on the Neutral Position Sensor. The other spade will then need to be grounded to any part of the chassis.
#65
Vendor - Former Vendor
on
Currently doing this swap with an 06 chassis. Beside drilling the clutch master mounting holes also had to take the top clutch pedal mounting bracket off a MT and add install it to properly mount the clutch pedal. Its on the firewall inside the car directly inder where the wiper motor mounts. What did everyone else do?
#66
#68
Nice job on the install. I had no idea you could install a bracket. I have done numerous 240sx swaps and the bracket is always there. Time for me to redo my pedal. BTW, did you take the spring out of the clutch pedal? I suggest you do since it gives the pedal much better feel.
#71
on
I could do basic work on my car but im not capable of doing this whole swap. My 5at is already going out, so i was already looking at $1000 to replace it.
Around how much for everything in total??
Anyone knows someone or somewhere this could be done in the so california area???
#72
#73
Or I have a low mileage automatic for sale on here (we're both in california too). Unless you're going for big hp this isn't the most cost effective route.
#75
on
Has anyone done this on the 07-08 chassis and if so are there any HR specific gotchas?
I'm contemplating the swap rather than having my 5AT rebuilt on my 08HR but I've not seen anyone do it on the later model cars yet.
#78
Give Dynosty a call and they can do the flash/set you up correctly so you don't start buying parts that won't work with each other.
http://www.dynosty.com/contact/
Phone number is at the bottom left of the page
#79
Sorry to revive a near six month old thread..
To those of you with the 6MT swap and auto ecu with the u1000 code, does your cruise control work (provided you have cruise)? The only thing I see in this thread referring to cruise control is the NPS, but on this z I get a cruise error causing the "set" light to flash. The NPS is working, confirmed by the idle up when put into gear. If U1000 does in fact prevent cruise from functioning, has anyone successfully turned off the U1000 code with Osiris and regained cruise functionality?
Just for background, this one is a 2005 using the MT harness (engine, trans, and harness all came from a 2005 non revup as well) and auto ecu. Reverse lights do not function; is this the case for others using the MT harness? I'd like to know before I troubleshoot the body harness any deeper. I appreciate any valid information.
Ross
Ross
#80
on
I'll bump it also. Hi guys i'm new here. Owner of a FX35 and infiniti scene forum member Raymond. I was doing some search about this swap and of course found many intell (as in the past with other questions as well) here on this forum. So thought it was time to join. My question is concerning the CD009 tranny belhousing. I was told this wouldn't fit the vq35de. That the housing is bigger and only fits the Rev-Up HR and 370Z engine....? Could anyone confirm this ??
