fuel tank removal
Old 10-16-2014, 06:38 PM
rauleb
rauleb's Avatar
Default fuel tank removal
Hello guys,
I have a hole in the bottom of my gas tank and I'm looking how to remove it so I can replace it? Or does anyone have another idea for a permanent solution?
Any suggestions are welcomed and appreciated!
Old 10-16-2014, 10:46 PM
KingBaby
Hardest Setting
KingBaby's Avatar
If visible and reachable a quick weld should and I say should fix it....other than that dropping the subframe is required
Old 10-17-2014, 07:02 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,290 Likes on 894 Posts
How the hell did you get a hole in the gas tank? My suggestion is to take it to a welding/fabrication shop that specializes in such repairs- this is not a DIYer if you want a solid and permanent fix.
Old 10-17-2014, 09:51 AM
KornerCarver
KornerCarver's Avatar
I could be wrong, but I thought the gas tank was plastic.
Old 10-17-2014, 11:07 AM
Syner
Syner's Avatar
Make sure you drain it first though...
04-22-2021 09:42 PM
11-09-2020 10:27 AM
Depravity
10-01-2015 04:49 PM
Quick Reply: fuel tank removal
